Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-30-2004, 09:46 AM   #1
wa3vez
Profile:
Battery Isolator
1990 345 Motor Home. The isolator is a four terminal type which requires a voltage from the ignition on the fourth terminal. The Airstream manual shows a wire connected to the alternator output post with a diode in series. This diode shorted out and was blowing fuses in the ignition circuit. The wire is a #16 red. I removed the wire and everything seems to work OK. The book says it goes to a sensor?? Does anyone know where it goes and what is its purpose. Thanks.
wa3vez is offline   Reply With Quote
Old 08-30-2004, 10:36 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
What alternator? Sounds like the sense wire for the regulator on a Delco.
John
74Argosy24MH is offline   Reply With Quote
Old 08-30-2004, 02:46 PM   #3
wa3vez
Profile:
Cool Mystery Continues
John
Standard high current Delco GM alternator. These require an excitation voltage from the ignition to work but I never heard of a sense wire. By the way these are in all of the Classic Motor Homes up to 1994 or 5 (at least in the Manuals). Airstream checked all of the manuals but has no idea what the wire is for. Neither does my dealer. Airstream is continuing the investigation. My GM RV Motor Home manual shows the wiring diagram for the isolator and they do not show any sensor lead at all. Big mystery.
Old 08-30-2004, 07:22 PM   #4
74Argosy24MH
Check it with an ohm meter back to the small red wire in the plug on the alternator. If it is the same wire, it needs to either be tied in with the black/brown wire in the plug or to a terminal that is hot when the ignition switch is in the ignition position.
John
Old 08-31-2004, 11:21 AM   #5
wa3vez
Profile:
John
There are three wires coming out of the alternator plug. One goes to the ignition, the brown wire is just hanging loose and is taped up. I believe this is for a dash charge light. The third wire is a red 16 gage one that may very well be the mystery wire. I have checked Airstream, several dealers, Chevrolet, Workhorse, and GM and nobody can tell me what this wire is supposed to do.
Old 09-02-2004, 12:27 PM   #6
wa3vez
Profile:
I got it and our Motor Homes are wired incorrectly. See new thread "Urgent! Alternator/Isolator is wired incorrectly"
battery isolator kooblekidz Airstream Motorhome Forums 5 08-28-2003 06:04 AM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Battery Isolator thenewkid64 General Motorhome Topics 20 01-12-2003 09:00 PM
Battery Isolator shelocta Airstream Motorhome Forums 1 10-29-2002 10:32 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
