Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 01-26-2005, 02:49 PM   #29
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Thanks alot Don that is what I was looking for
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 01-28-2005, 01:15 PM   #30
85/345
Profile:  Marietta , Georgia
I checked the cutoff switch I have and it definetly is a cutoff for the coach/house batteries. I don't have one for the chassis battery but that is on my list of things to do.
Another note about the new alternator I installed. It is not putting out enough amps/volts (not sure which one) according to the guage on the dash. It is reading around 12. From what I know isn't it supposed to be reading around 14? I am assuming and Alan reaffirmed this with his post that the alternator isn't big enough, not enough amps. If this is the case do I need to change it or just use it until it dies?
Thanks, Brian
85/345 is offline   Reply With Quote
Old 01-28-2005, 04:47 PM   #31
74Argosy24MH
Profile:  LOST , Hawaii
It is a voltmeter and don't trust the factory gauges; they are good to see a trend, but not really accurate.
Got a good digital meter? Check the output right at the alternator. If you have an isolator you are loosing 1/2v at least there, more through the rest of the harness.
I would use the alternator you have and see how it works. Unless you really drag the house batteries down it will get them back up ok. If you do go with a high output altenator you have to change the wiring to the batteries and the isolator.
John
74Argosy24MH is offline   Reply With Quote
Maintaining your Batteries joshua32064 Batteries, Univolts, Converters & Inverters 17 04-29-2008 10:03 PM
Can't get batteries charged -- why not? neil.ervin Batteries, Univolts, Converters & Inverters 23 11-14-2004 07:24 PM
???s about Batteries & Solar joossens Generators & Solar Power 6 06-01-2004 09:51 AM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 02:34 PM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
