Old 10-04-2012, 08:34 PM   #15
1995 36' Classic 36
Ludington , Michigan
Originally Posted by AdamB View Post
I did get a quote from my diesel mechanic regarding the exhaust brake and it was not going to be an inexpensive undertaking. I didn't write it down, but I think it was like $3-$4k due to the valve springs replacement. I drive a rig at work worth 10 times as much as my Cutter with a modern exhaust brake, so it's a little unnerving downshifting the Cutter and stab braking on all the hills. I actually think I would get the exhaust or Jake brake first....
I hope your current trip is going well. You can click on my profile to see how one of our trips this year took a little detour. All was good in the end though.
Went over Monarch Pass at 11,300 feet the other day. Did real well bout up and down. Proper technique is definitely required. I can do the install myself including the valve springs so I might tackle a Pac Brake this winter.
Name:	Fall 2012 326 (Large).jpg
ID:	169549   Click image for larger version
Name:	Fall 2012 328 (Large).jpg
Kota is offline   Reply With Quote
Hot Water Radiant Heat - My Installation malconium Plumbing - Systems & Fixtures 82 01-30-2012 01:40 PM
WDCU : WDCU Fall Installation "Buddy" Rally TWaugh WBCCI Rallies & Events 20 10-24-2011 04:19 PM
Outer Banks Trip Memorial Day 2011 FLMarine On The Road... 3 06-29-2011 04:58 AM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
