Old 11-24-2015, 08:33 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Ball joint replacement
The Moog upper and lower ball joints arrived and I am planning on installing them in the near future.
Napa has a loaner tool kit to press the new ones in, getting the old ones out appears to require a specialty tool.
Anyone done this ?
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 11-24-2015, 10:13 PM   #2
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Moving forward as usual Peter. :-)
I just changed tie rods on my Porsche. To separate the ball joint at the outboard ends I used a special tool. It's a wedge shaped tool .
With a slot in the center section and a stout handle that you pound on to drive the sharp end of the wedge into the center gap of the ball joint till it pops open.
Maybe a truck parts store would have a big one to rent.
Keep us posted on how this job goes for you.
Cheers Richard
tevake is offline   Reply With Quote
Old 11-25-2015, 03:10 AM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
A ball joint separator can be used, or if you are fairly coordinated, you can loosen the castellated nut on the ball joint, and whack the hell out of the spindle where the ball joint is attached.
Old 11-25-2015, 03:41 AM   #4
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
We call them a pickle fork around these here parts
Name:	ImageUploadedByAirstream Forums1448448072.930262.jpg
mayco is offline   Reply With Quote
Old 11-25-2015, 04:55 AM   #5
Airstream Driver
1997 30' Excella
Images: 51
These can not be removed with a picklefork nor by impact with a hammer, since the balljoint housing itself is pressed into place
AIR #13
Old 11-25-2015, 05:00 AM   #6
Well Preserved
1993 21' Sovereign
I think all of us thought you were talking about removing the ball joint from the spindle, so you could remove the joint. Once you get the joint separated from the spindle, you'll need what is called a ball joint press. An impact gun to turn the threaded bolt in the press will be mighty handy, though not strictly necessary.
Old 11-25-2015, 05:06 AM   #7
mayco's Avatar
Ahhhhhhhhh. I watched as he did mine and I dont recall him using a press or pickle forks. I do remember a 2lb sledge being involved but my memory just sucks. He did the broken side on site and had very few tools with him. Dog gone it Peter, I stood there and watched and cant remember..sorry. If I recall Ill let you know.
Mike
Old 11-25-2015, 05:29 AM   #8
Airstream Driver
1997 30' Excella
Images: 51
Mike
the 2lb sledge hammer way is what I am trying to avoid. He must have had some kind of a press to remove the joint, besides loosening the tapered part of the joint.
AIR #13
Old 11-25-2015, 05:32 AM   #9
Airstream Driver
1997 30' Excella
Images: 51
Terry,
Yes, I was wondering if the press tool to install it, can also remove it with the proper attachments. Sorry for not being clear in the beginning.
AIR #13
Old 11-25-2015, 05:34 AM   #10
Well Preserved
1993 21' Sovereign
The press looks like a really heavy-duty C clamp. It comes with several sleeves, spacers, and adapters, so you don't destroy anything.
Old 11-25-2015, 05:42 AM   #11
mayco's Avatar
Thats what he used Terry.
Old 11-25-2015, 05:44 AM   #12
Well Preserved
1993 21' Sovereign
Terry,
Yes, that can be used to remove and install ball joints.
It's also handy to replace U-joints in the driveshafts.
Old 11-25-2015, 05:57 AM   #13
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Try a Snap-On BJP1, An excellent tool, as a bonus it includes the u-joint press for the driveshaft, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 11-25-2015, 07:08 AM   #14
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I did the ball joint project on my 4wd pickup truck three weeks ago and used a kit like the one pictured above in post #9. It is a tough job. I am a mediocre shade tree mechanic.
I am not familiar with the front end components of a motor home. For my 4wd application new ball joints can be purchased with smooth sides or splined sides. The smooth sides were for typical applications where the bore that holds joint is not worn out or enlarged. The splined models were for a bore that was enlarged. I don't know if this will pertain to the motor home front end or not.
For my project I needed:
- a kit as pictured above
- penetrating fluid - soak the joints a day or so ahead of time
- torch to loosen things up - (one joint was particularly stubborn)
- 3/4 inch drive with cheater bar on the ball joint press to get the joints moving
- a few extra large washers/spacers
- place the new ball joints in a freezer for 24 hours or more before installing makes the install easier
- anti-seize lubricant for the ball joints
- block of wood and large hammer to remove the tie-rod (pickle forks can cut the rubber boots on the tie-rod end)
- assortment of open end/ box end and sockets (1/2" and 3/4" drive)
- torque wrench for ball joints and tie rod end
Take a few pics along the way - I'm curious what your getting into.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
4CU 004 : FCU/NM unit joint rally Ken J WBCCI Rallies & Events 2 03-07-2009 06:29 PM
Pennwood Joint Buddy Rally August 3-5, 2007 alvinator The Rally Zone 3 08-14-2007 08:00 PM
David Crosby and Graham Nash Announce Their Candidacy for Joint Presidency Andy R Airstream "In the News" 11 08-02-2004 09:28 AM
SCCU ENCU Joint Rally white1949 WBCCI Rallies & Events 0 03-09-2004 06:14 PM
ENCU SCCU Joint Rally white1949 WBCCI Rallies & Events 0 03-09-2004 06:00 PM
