Old 12-05-2015, 08:32 PM   #29
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Nice work Peter. There is nothing like the piece of mind you get driving down the road knowing the job was done right.
Gregsch is offline   Reply With Quote
Old 12-06-2015, 06:37 PM   #30
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Left side went a lot faster than the right side. The on the job training is paying for itself already.
Just right after I took the picture of the extensions used to torque this puppy in, we busted my wrench and I had to get another 3/4 drive socket to finish the job.
Thanks to my friend Joe for giving me a helping hand and for applying his usual wit to solve the unsolvable!!
My recommendation:
Unless you have the right tools, do not attempt this job!
I was lucky that I purchased the original GM installer tool, without it we would have been sunk.
below the perfect fitting tool to make this possible
GM specialty tool #J-9519-10 with adapter J-9519-16
and a fence post
ID:	253457   Click image for larger version
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-08-2015, 07:12 AM   #31
Peter, got any pictures of removing the coil springs?
Great job by the way!
Old 12-08-2015, 12:57 PM   #32
Airstream Driver
1997 30' Excella
Images: 51
Coil springs, airbags, shocks all stay. Caliper and rotor come of.
You would have to remove the coil springs etc , if you would want to use a hydraulic press.
This method is called "on vehicle ball joint replacement"
1996 Airstream B190
AIR #13
Old 12-08-2015, 02:44 PM   #33
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Peter
Where did you find that ball joint press. That is something I would like to have.
You don't have to remove the calipers and rotor to re&re the coil springs.
shepherd57 is offline   Reply With Quote
Old 12-08-2015, 03:01 PM   #34
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by shepherd57 View Post
Peter
John,
But you have to remove the caliper and rotors to RR the ball joints. I didn't remove the springs.
I found only 1 on ebay, from someone in Maine. I believe it has been long discontinued.
1996 Airstream B190
AIR #13
Old 12-08-2015, 04:11 PM   #35
Airstream Driver
1997 30' Excella
Images: 51
Here is a very pricey (450.-) entire set
Kent Moore J 9519 E Ball Joint Service Kit Remover Installer Set Tools | eBay
1996 Airstream B190
AIR #13
Old 12-08-2015, 08:45 PM   #36
Airstream Driver
1997 30' Excella
Images: 51
By request, here are the dimensions for the press-in adapter J-9519-16
2 1/2 " x 1 1/4
Without the notches in the C clamp, it would not fit.
ID:	253568   Click image for larger version
ID:	253570   Click image for larger version
1996 Airstream B190
AIR #13
Old 12-09-2015, 06:22 AM   #37
Thanks Peter!
Old 12-15-2015, 05:57 PM   #38
Well thanks to an alert forum member I'm now the proud owner of a well used J-9519-10 ball joint press tool. It's not as pretty as Peter's is but it should do the job just fine
The adapter that came with the tool does not appear to be one that is used on a P-30 ball joint rebuild which means I'll need to fabricate whatever adapters are needed on my lathe.
Old 12-15-2015, 06:09 PM   #39
Airstream Driver
1997 30' Excella
Images: 51
Attachment 253908
Attachment 253907
Heavy duty, isn't it. In case you haven't figured it out that adapter snaps on. Took me a while to figure that out. I thought mine was permanently attached.
1996 Airstream B190
AIR #13
Old 12-16-2015, 06:32 AM   #40
Peter, after reading your comment and looking at the picture you had posted previously I tried tapping the adapter off with no luck. The adapter spins on the shaft but will likely take a little bit of effort to get it off. I'll try again tonight.
Last night while relaxing in the recliner I was browsing through the 74 Light Truck service manual for my Argosy and ran across this page:
This page caught my attention because it mentions that the J-9519-10 press tool needs to be modified for use on a P-30 chassis! That got me to thinking back when I was dismantling the 345 I noticed that the parts on the 345 seemed to be beefier than on my 345. I remember doing some comparisons and there were some definite differences between my Argosy and the 345.
It would appear the differences are enough that the J-9519-10 press would need to be modified. What I don't know is if after the modification will the press still work for the later Classic's?
The next thing that caught my eye was this page:
The two adapter part numbers (J-9519-7 & J-9519-9) don't match with the ones that Peter used for his ball joint removal and replace. So being bored I decided to check ebay to see if these adapters might be available. Sure enough both were listed in separate auctions and both had "Make Offer" available. I made somewhat low-ball offers and both were accepted!
In theory I now have the correct tool for removal and replacement of the lower ball joints for the early (probably all) Argosies. I won't be modifying the ball joint press until I know for sure that it won't work as is on mine. Bottom line is if I have to modify it I will but it would be nice not to have to do so.
Old 12-16-2015, 08:06 AM   #41
Poking around online I came across the service manual for 1978 model trucks and the manual doesn't show any modification to the J-9519-10 press tool but it does show the use of an additional adapter J-9519-2 (no picture shown of course) that might alleviate the need to make the modification to the tool.
A quick spot check on RockAuto comparing ball joints from 1974, 1978 & 1984 shows the same ball joints used in all three years. I was hoping to find a difference that might explain why the J-9519-10 press would need to be modified but didn't find a smoking gun
Oh well, when the time comes I'll either modify it or not depending on circumstances.
Old 12-16-2015, 01:48 PM   #42
Airstream Driver
1997 30' Excella
Images: 51
Brad, the tool itself never needs any modification, the adapters you use may, unless you have J 9519-16. This is the most important adapter that snaps on where your current adapter is. And yes it will come off, just try a little harder.
I checked and your year and my year take the same Moog number, so there can not be any difference.
Remember the removal was the easy part and i used a rental tool and 1 adapter as I described before.
ID:	253970   Click image for larger version
1996 Airstream B190
AIR #13
4CU 004 : FCU/NM unit joint rally Ken J WBCCI Rallies & Events 2 03-07-2009 06:29 PM
Pennwood Joint Buddy Rally August 3-5, 2007 alvinator The Rally Zone 3 08-14-2007 08:00 PM
David Crosby and Graham Nash Announce Their Candidacy for Joint Presidency Andy R Airstream "In the News" 11 08-02-2004 09:28 AM
SCCU ENCU Joint Rally white1949 WBCCI Rallies & Events 0 03-09-2004 06:14 PM
ENCU SCCU Joint Rally white1949 WBCCI Rallies & Events 0 03-09-2004 06:00 PM
