Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 01-10-2005, 04:47 PM   #1
Paul Daugherty
Paul Daugherty's Avatar
Profile:
Bad light switch
82 310 bad light switch the one that is a three way that works the lights in the front of the coach. Where would I find another one? Thanks Paul...
Paul Daugherty is offline   Reply With Quote
Old 01-10-2005, 05:37 PM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Would you happen to have a picture of the switch? Depending on the shaft length, some switches are available at home improvement stores. But if they are like mine, they are only available at Airstream dealer$.
Tom
Old 01-15-2005, 07:01 PM   #3
Paul Daugherty
Profile:
NO bad Switch
I found a switch but it still blew the 20 amp fuse so what next? Run a wire from the switch to the box to check ohms? if open it is going to ground some where and if so how in the world do you find it?
Old 01-15-2005, 07:54 PM   #4
LLB21
LLB21's Avatar
Profile:
Try C&G Trailer Service in Bellflower, CA. Website address is www.CGTrailer.com.
They have really helped me out.
Louie
LLB21 is offline   Reply With Quote
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 12:44 PM
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 06:31 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
