Old 02-04-2012, 04:15 PM   #1
Automatic Transmission Cooling.
Spotted this great link and article over in the Towing section, and thought it was worth reposting here..
Automatic Transmission Cooling | OldIHC
Old 02-07-2012, 09:45 PM   #2
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Thanks Key,
That's a good article to keep on file.
streamquest is offline   Reply With Quote
Old 02-08-2012, 12:04 AM   #3
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Good article. With the exception of my current tow vehicle (V10 SuperDuty) that has a factory transmission cooler the size of the radiator, I have always installed a heavy duty trans cooler and have never had transmission problems. In 1977, my father outfitted his (now mine) Cadillac with a radiator mount cooler as well as a pan cooler to tow the airstream. All these years later the Turbo 400 transmission is still good as new. I had it serviced a coupe of months ago for the first time in 9 years and the mechanic wanted to re-use the fluid because it was so clean. I told him to replace it anyway. I took my V10 to the transmission shop to inquire about an additional cooler and they said these new transmissions were sensitive to running too cold and that the factory cooler was more than adequate. After towing up steep grades for long distances and noticing my trans temp guage never moved, I would agree.
4RXLA is offline   Reply With Quote
Old 02-08-2012, 06:42 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Doug,
Very true...the newer tranny's are very sensitive too cool running problems,
especially up North here.
If you need to install an aux cooler make sure it has a thermostat by-pass feature. B&M.
On GM's.... if you have a trans temp gauge you'll have a very good cooler and should not need the aux....my experience anyway.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 02-08-2012, 06:52 AM   #5
dznf0g's Avatar
Oswego , Illinois
Understand that the newer version of trans fluid, at least for Dexron, are not as prone to thickening up in cold temps as the older versions. I believe that is why the new transmissions are equipped with more cooling capacity.
I have noticed that with the six speeds factory filled with Dexron VI, the transmissions run as much as 30 degrees cooler than the four speeds with Dexron V. That 30 degree differential is true whether running solo or towing.
-Rich-
Old 02-08-2012, 07:14 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Keyair,
Thanks for sharing the article! It gave me some answers I have been wondering about. My silverado's trans temp gets up in the low 230's when going over the mountains. I did not know what the max temp should be. I did not think I was getting close to overheating, but now I know that is not to hot!
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 02-08-2012, 07:31 AM   #7
Thumbs up
The PCM will go into "limp mode" if over 285 for an extended period. (speed and shift restriction).
Our Burb averages 150-210 while towing. 225-235 heavy load/long grades.
W. H. Auden
Amanamus
"Tahawus"
Old 02-08-2012, 08:54 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The Silverado is about the same, even when the temps are in the upper 90's.
I have not towed out in the southwest, yet, so I'm wondering how it would be out there. Any others that will share there experiences?
Alan
Old 02-08-2012, 09:24 AM   #9
dznf0g's Avatar
Oswego , Illinois
What I found on the 4 speeds, across the GM product line was: running solo in the flats of the midwest, the many company trucks I have had, run 80 - 90* over ambient temperature.
The 6 speeds with Dexron VI (I've driven 3 of them thus far) run only 50 - 80* over ambient.
Towing is too variable (weight, headwind vs. tailwind etc) to assign an accurate range, but I have noticed it to be about the same reduction in the temps while towing.
-Rich-
Old 02-08-2012, 09:37 AM   #10
Cracker's Avatar
Pittsfield , Maine
I just noticed the other night, while driving home to northern Maine from Portland, Maine, no tow, that the transmission temperature gauge for the Allison was just barely off the 100 degree mark at the bottom of the scale. We were doing about 65 mph, with the air temperture at about 19 degrees. I was beginning to wonder if I had a defective gauge since, as I recall, I usually show about 120 to 125 degrees when not towing, even on the coldest winter days??? Have others noted readings (---or "non readings") this low with the Allison?
Cracker
Cracker is offline   Reply With Quote
RV Cooling Unit Warehouse dznf0g Refrigerators 5 08-07-2013 06:24 AM
Transmission service woodja Classic Motorhomes 21 07-29-2013 08:53 PM
Dometic Cooling Unit Failures wasagachris Refrigerators 7 08-30-2011 05:08 PM
Cooling problem on gas Pahaska Refrigerators 38 08-22-2011 05:18 PM
Clipper, Class A, Air Brakes, Automatic Slacks masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 0 04-16-2011 04:05 PM
