Old 12-28-2011, 01:04 PM   #1
1991 36' Land Yacht
Catawba , Virginia
ATF v:s PS Fluid
Trying to iron out all the bugs in my power sterring/autopark/hydroboost system and need to purge the air out of the system after replacing a hose. The PO put ATF in the pump reservoir. The owners manual states that ATF can be used in an emergency. The service manual states to flush the unit after any repairs. Has anyone done this procedure and what is the best way to accomplish this to get it out of all the components. 1991 Airstream Land Yacht 36 w 454cu in.
Road Dawg 36 is offline   Reply With Quote
Old 12-28-2011, 04:27 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Fill reservoir with PS fluid.
Start engine, turn steering wheel lock to lock.
Remove fluid in reservoir using your favorite fluid removing tool.
Refill reservoir.
Turn wheels again lock to lock.
Drain reservoir again.
Repeat until ATF is gone from reservoir.
Old 01-07-2012, 10:43 PM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I was wondering if while holding down the brake peddle,waiting for brake light to go out, do you hear a loud vibration noise. Thats what mine did when it had air in the system, after I had the leaking reservoir replaced. The air worked itself back and foamed out through the reservior.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
P-30 Transmission Fluid change interval crazeevw General Motorhome Topics 11 12-08-2011 03:59 PM
Actibrake leaking brake fluid adonh Brakes & Brake Controllers 7 11-13-2011 05:12 PM
Portable fire pits. Boondocker Boondocking 56 09-30-2011 04:07 PM
Brake Fluid Reservoir Barb H. Land Yacht/Legacy Motorhomes 2 08-08-2011 08:03 AM
Can I add hydraulic fluid to jacks? lululand Jacks, Stabilizers, Lifting and Leveling 5 06-08-2011 02:47 PM
