Old 09-18-2011, 04:45 PM   #1
2000 31' Land Yacht
Fort Erie , Ontario
ASLY 2000 1999P32 Exhaust header leak
Hi All
Have an exhaust leak RHS on the 454. Does anyone have part # for copper gasket replacement. Also is it necessary the studs be replaced at same time.
Any suggestions would be appreciated.
Regards,
Steve
is.chowa is offline   Reply With Quote
Old 01-13-2012, 10:25 AM   #2
2000 31' Land Yacht
Fort Erie , Ontario
Exhaust Header Update
Found both OEM headers were cracked and replaced both with Banks kit,new bolts, did not need a gasket. Runs nice n quiet.
Steve
Old 01-13-2012, 10:45 AM   #3
1982 28' Airstream 280
Redwood City , California
Glad you got it fixed. That is why my dad put on the banks system years ago...manifolds kept cracking and leaking. I have a small leak on the right side right now. Hopefully I can tighten the header with my rusty studs and nuts!
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 01-13-2012, 04:30 PM   #4
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Sorry I didn't see you posting sooner. The folks that ride in my 345 are amazed that the engine is between the 2 of us, Banks system is that quiet. Even at that sewer pipe sized exhaust, it's not that objectionable. Have to admit, sometimes I wish it were a dual exhaust.....guess that's the 'gearhead' in me, huh?
Thanks, Derek
Old 01-20-2012, 09:56 PM   #5
2000 31' Land Yacht
Fort Erie , Ontario
While I was at it, replaced plugs (they were original oem) wonder how it ran. Also new wires, Air bags were leaking got rid of them put in SS springs, bellcranks drag link tierod end and two tires and of course alignment Oh and shocks. She runs and handles real good. I think that YL can now drive it.
Getting rid of the bags was the best thing I could have done.
Steve
Old 01-28-2012, 06:09 PM   #6
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Steve, I also replaced my front airbags with the SS coilsprings and I'm very happy with the results. When I first got my LY I had the same problem with leaking manifolds, a common problem with the 454, and opted for the Banks system also, and have had no problems since. Looks like we've made alot of the same improvements for a better drive.
Randy
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 01-29-2012, 08:08 AM   #7
2000 31' Land Yacht
Fort Erie , Ontario
Randy
Yes, the better less tiring ride is important. Prior to changes, co-pilot was relegated to be navigator we will see on next trip (end Feb) if she wants to try sailing ASLY herself.
The front tire change was needed due to the misalignment when the one bag went flat. And being the maiden voyage for me, was oblivious to the problem that this caused.
Next project when we get back from FL will be to tackle the moisture ingress much like what Santart did previously when it gets a bit warmer here.
Have you or anyone else removed the windows? The answer I got was to remove the interior window trim, remove the rubber gasket under which there are the screws securing everything ???
I got the sample interior "wallpaper" from AS but it doesn't match what I have. Would love to post photos but am having probs with the "security missing" token so can't do much until that issue is resolved. Even tried by setting up an account under "s.chowa" same prob.
Steve
Old 01-30-2012, 09:52 PM   #8
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Steve,
Before we purchased ours, the owner just handed me the keys and said take it for a ride. It was a very windy day, I tried to get my wife to take a turn driving (I-75 near Detroit here in Michigan), exhaust noise, wind noise, rattling along with the play in the steering - she would have nothing to do with it. After making many of the improvements we've talked about , she now does almost all the driving. So...just a warning, it you get it driving too nice you might lose your driving privileges
Randy
2000 25' safari fresh water leak dcsawLoehr 2000 Safari 6 07-29-2012 09:25 PM
Kitchen exhaust & cover missing Sheepmate Roof Vents, Skylights & Fans 0 07-27-2011 01:02 PM
Water Leak bumper Airstream danyfr67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 06-07-2011 07:43 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
