08-20-2011, 07:25 PM
Fred's Airstream Archives
1977 20' Argosy 20
Charleston
, West Virginia
Argosy 20' MH Chevy 350 - engine soft plug?
While traveling through West Virginia, I spotted an Argosy 20' motorhome. I've traveled the route many times before and missed this little unit each time!
I knocked on the door and the unit is for sale!
Q) The owner indicated that the "soft plugs" are bad and need to be replaced. I am guessing that these are "Freeze plugs" or "casting plugs" on the engine block. How big of a job is this to replace on a Chevy 350? What does this indicate about the status of the engine?
The engine does start up. He also indicated that the muffler needs replacing.
Now I just need a larger yard and driveway!  It is a nice unit that has been stored under a carport. The gen set is not connected. The tires, fridge, and A/C needs replacing. The wife is on board so that takes care of 90% of my battle.
08-20-2011, 08:05 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
While i am not familiar with the P30 chassis, I do know that on 1970s Chevrolet pickups, it was possible to replace all of the the freeze plugs from beneath with the vehicle on a lift. There are typically two major causes of problems that cause freeze plug failure that I am aware of . . . failure to maintain sufficient antifreeze in the system . . . or . . . corrossion caused by failure to change antifreeze frequently enough.
While it isn't necessarily the death knell of a motor to have failed freeze plugs, it does raise questions about maintenance over time. - If the cause was failure to maintain sufficient freeze protection. . . .
- Was the freeze damage enough to crack the engine block?
- Was the freeze damage enough to crack one or both heads?
- Was the water pump damaged?
- Was the radiator or either of its tanks damaged?
- If the cause was failure to change antifreeze frequently enough . . .
- Are coolant passages in the block blocked with particles of corrossion?
- Are coolant passages in the intake manifold/heads blocked with particles of corrossion?
- Are the tubes of the radiator blocked with corrossion.
Of course if one has exceptionally good luck the cause could just be age and lack of use.
Gook luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
08-26-2011, 04:11 PM
Airstream Newbie
Torrance
mind if I ask what the asking price is for it? I'm looking at the larger '28 model from '78 that sounds like the engine may be in better condition.. Just curious to compare notes.. Thx!
08-26-2011, 05:15 PM
1977 20' Argosy 20
Charleston
, West Virginia
He is asking $4,500. It think that is a lot since it needs engine work, a muffler, a new fridge, new A/C, new tires, exterior paint, new upholstery, and the gen set is disconnected. I'll have $10,000 in it in nothing flat.
I have units listed on my site for around $10,000 with new engines, tires, and in much better shape.
08-26-2011, 05:20 PM
1977 20' Argosy 20
Charleston
, West Virginia
The 1978 will have the air bag suspension. The big thing with the 28's is the floorplan. I have found that the center sofa/double with the rear bath is very common and fairly unpopular. The center twins or the rear salon are the more desirable 28' floorplans but you have to get what works best for you.
The 20' I looked at was a 1975.
08-26-2011, 06:40 PM
1963 19' Globetrotter
1979 Argosy Minuet 6.0 Metre
1975 20' Argosy 20
Gulfport
, Mississippi
I like the 20' MH size, you can park it anywhere. I paid $3,500 for my 20' Argosy MH, it was runnig, but I did replace the 350 engine and the 400TH transmission. $10K goes fast & it's hard to get all that money back if we sell it, but who would ever sell it!!
Still working on ours, stuck on the window channel felt (of all things!).
http://www.airforums.com/forums/f463...-mh-42788.html
Is it a rear bathroom or front bathroom?
Good luck!
08-26-2011, 07:59 PM
1977 20' Argosy 20
Charleston
, West Virginia
Rear bath. It is just like this unit (but not as nice). I like the rear salon model but it only leaves one bed which is the fold out couch. I want to make sure we have comfortable sleeping arrangements. One couch won't cut it.
We probably would have bought it for $3,500! He is very determined to get the full $4,500. I have his number! I'll just keep in touch every few months!
Question: When your replaced the transmission, is it the exact replacement or one that runs better at 65-70mph? The thing I really hated about the 345 was that it was geared for 55 mph. Running at today's highway speeds really taxed the engine.
02-18-2012, 03:58 PM
1977 20' Argosy 20
Charleston
, West Virginia
Here is the latest and my dilemma with this 1975 Argosy 20' ...
I am going Tuesday (2/21/2012) look at the unit again. The current owner does not run the engine long due to the low coolant. The coolant is very low. I could bring water and coolant with me and hope I could nurse the unit 2.5 hours (140 miles) back home. I REALLY do not want to replace the freeze plugs because I ultimately want to replace the engine. The unit has sat under a carport for several years (guessing 5-7 years). It has a current tag but expired inspection sticker.
Option 1: Try to drive it home and take my chances. Watch the engine temp carefully, hope for a REALLY cold day (forecast high of 52)!
Option 2: Get the freeze plugs done locally and then drive it home. With this option, I would keep the existing engine and see how it goes (53,000 miles on the unit).
Option 3: Get the engine replaced locally (near the unit) and then drive it home
02-18-2012, 05:47 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
One consideration is that small-block Chevy's have a pair of core casting plugs on the rear of the engine that are inaccessible while the flywheel (standard transmission, NA in this case) or torque converter (automatic transmission) is in place. The ones on the side are easy, but the two on the back require more labor. If it's just the ones on the sides leaking, I'd replace them.
Another consideration. On a cool day, you should be able to drive short distances with the system not pressurized. As long as the coolant doesn't exceed boiling, leaving the radiator cap off or loose would keep it from building up pressure and forcing it out the leaking plugs. It would also simplify adding more coolant during the trip. You could just pour more in the top while the engine is running. I would think that 140 miles is doable.
Still, with only 53,000 miles on it, I think I would get the casting plugs changed. There could be a lot of life left in that engine.
BTW, since they are so common, 350 Chevy engines are the cheapest engines to work on. A definite plus.
Vaughan
02-18-2012, 06:01 PM
1977 20' Argosy 20
Charleston
, West Virginia
This is where I am confused (as a total non-mechanic). The owner is saying that the soft plugs (used in the casting) are the issue but he also says that it is leaking coolant (which sounds more like the freeze plug). Does the 350 have both the "casting plug" and a "Freeze plug"?
02-18-2012, 06:08 PM
1977 20' Argosy 20
Charleston
, West Virginia
Tell me if I understand this correctly. The casting plug that keeps in the coolant that is circulating around the engine is leaking. This would explain why the coolant is low.
I am now thinking this has nothing to do with the "freeze plug" in between the oil and coolant. It seems now the question is just how big the leaks are?
02-18-2012, 06:26 PM
1977 20' Argosy 20
Charleston
, West Virginia
I guess I am showing my ignorance because it seems that casting plugs and freeze plugs are the same thing. Coolant leaking out to the ground is one thing, coolant leaking into the engine is another. Do the different plugs leak in different ways?
02-18-2012, 06:57 PM
Oswego
They are the same thing. Freeze plug is really a mis-nomer. If a block freezes it will crack in all sorts of places and the casting plugs won't save the block as is commonly thought. There are casting plugs and oil galley plugs in a block and are necessary for the manufacture of a block. They start leaking, most commonly, due to corrosion.
If it is leaking coolant from one of these plugs, it is a casting plug. How bad the leak is really answers your question on whether you can drive it home.
"All I want in this life of mine..... is some good clean fun" - Little Feat
02-18-2012, 09:08 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Correct.
That's kind of a strange question, since in your first sentence you correctly identified them as the same thing.  They don't leak differently because they're the same thing.
dznf0g is correct in all his comments.
The name "Freeze Plug" is more than a misnomer, it's just plain wrong. They are actually core casting plugs. They are plugs that fill the holes where the sand molds that form the internal water passages are washed out, leaving the water passages. They are an artifact of the manufacturing process.
The name Freeze Plug goes back to very early engines with extremely thick iron castings that would sometimes survive a mild freeze without cracking, but the expansion would force out the casting plugs. The legend came up that they were "Freeze Plugs" that saved the engines, and the name stuck. The thick castings were the reason they survived. Modern engines with thin-wall castings will not survive freezing. Modern in this case means sometime in the 1930s or so.
There is no such thing.
You are correct about the difference between water leaking onto the ground vs. into the oil. The casting plugs (freeze plug is wrong, but a common piece of slang) are on the exterior side of the water passages, so they should leak onto the ground.
If you are getting water in the oil, something else is wrong. The best case is a head gasket problem. Worst case is a cracked block or head. These problems are much more unusual than casting plugs that have rusted and developed a leak.
Vaughan
| Thread Tools |
| Display Modes |
