Old 08-28-2009, 08:31 PM   #15
1974 24' Argosy 24
Davenport , Florida
The compression test today didn't go so well. Cyl 1 = 70lbs, 2=75lbs, 6=65, 8=70lbs. So I guess it is safe to say that the timing chain jumped.
It's really strange that it was working fine when we pulled into the gas station and turned it off. As was mentioned, the bad gas probably caused a miss fire which jerked the chain.
Now for the fun part. I can see I'll have to remove the grill, then the radiator. While I'm at it, I suppose all the belts and hoses should be replaced and the radiator cleaned out.
My main concern is not so much doing the work, but keeping my families faith in the Argosy. We have had so much fun, he is like a part of the family. (Somehow the picture just fits the situation)
Name:	100_1366 (Large).jpg
scottf3334 is offline   Reply With Quote
Old 08-28-2009, 08:45 PM   #16
IPM
1996 clipper gas 34'
Blue Springs , Missouri
Radiator is easier to drop out of the bottom if u first get the front high off the ground. I drove up on a set of auto ramps.
IPM is offline   Reply With Quote
got that sick feeling - with my *new* TV funkill Tow Vehicles 34 04-07-2009 08:37 PM
O what a feeling millvalleyca Hitches, Couplers & Balls 10 10-27-2008 05:59 PM
Ignition system advice needed rdm Mechanics Corner - Engines, Transmission & More... 6 10-14-2006 10:53 PM
Feeling Overwhelmed Olivia Member Introductions 20 07-04-2006 08:51 AM
sinking feeling joewinfield Sinks, Showers & Toilets 5 02-02-2006 06:19 AM
