Old 05-11-2004, 08:27 AM   #15
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
With that choke plug messed up you may not be getting a good connection. Be sure that choke is fully open.
Did you play with that screw on the top of the rear door any? It sounds like the secondaires are coming in a littl etoo soo and causing your rich condition. The way that thing works is the spring tension is such that the engine has to pull enough air though the top doors to pull them open. Too little tension and you will run rich at 3/4 plus throttle. The bottom plates should not open below 3/4 throttle.
For base line idle I like to use a vacuum gage. Set idle to 650 RPM. attach the gage to a central port (thermac for the Aircleaner connection on passengerside near choke is usually a good one). adjust each screw till your pulling the most vacuum. Repaet a coupel times to fine tune. Once your pulling the most vacuum the give each screw a 1/8 turn lean (clockwise). Readjust to proper idle speed.
The reason this works is the closer you are to optimal fule mixture the harder the engine is going to pull vacuum. At idel being a little lean is fine because there is no load. The accelerator pump will gt it rich for acceleration till the mains can come online with air moving though the venturies.
If that doesnt cure it may be float adjustment time. There is a little tool you can use to see the float level without takign it apart. Should be instrucktions with the information in the rebuild kit.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-11-2004, 08:49 AM   #16
87MH's Avatar
1978 31' Sovereign
Images: 292
Modifying Steven's Question to Give Steven the Answer
First the good:
And now the secondaries open up. Makes all kinds of power and soudns great through those headers - big smile the first time I did it
Now the bad:
Steven:
Welcome to the real world (and mileage identical to mine ).
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 05-11-2004, 09:43 AM   #17
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Dennis - very funny!
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 05-11-2004, 10:24 AM   #18
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
its like that Twilight Zone episode where all fluffy adjectives disappeared from everyone's writing...only the facts nothing but the facts!
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-11-2004, 11:04 AM   #19
RivetAddict
swebster's Avatar
It certainly feels like the Twilight Zone! Except this is the episode where after you fix everything on your MH it starts to run like crap and gets lousy mileage!
Maybe it's not the MH. It could be the mechanic!
Not that I don't aspire to be just like Dennis in everyway possible but if there is one thing I want all to my own it would be to have my old mileage back. Not even going for the "10% - 20%" increase often extoled by those who have added headers. Plus I just don't like changing plugs every 500 miles.
Alan - wanna trade? Think of all that extra room and the rear bedroom and the wrap around windows. My 345 could be the perfect RV for you!
Steven Webster
AIR 1760
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 04:35 PM
Trip report (fuel filter issues) PeterH-Airstreamer Airstream Motorhome Forums 10 08-01-2003 05:57 AM
Fuel Filter Replacement ViewRVs Mechanics Corner - Engines, Transmission & More... 8 03-06-2003 06:05 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
fuel pressure PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
