Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 01-01-2008, 11:45 AM   #1
peck1937
Profile:  spokane valley , Washington
Cool Antifreeze leakage
We have a 1998 airstream motorhome with 454 vortec eng. that consumes approx. one pint of antifreeze per 150 miles, have had it pressure tested twice and fassed the test okay, changed out the rad. cap twice, still consuming antifreeze.
Any insights out there ??
peck1937 is offline   Reply With Quote
Old 01-01-2008, 12:05 PM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Heater core?
Do you ever smell any inside or outside?
Old 01-01-2008, 12:21 PM   #3
gunner
Gunter
gunner's Avatar
Profile:  Greenville , Ohio
If it has similiar features as the Classic Motorhomes there are radiator hoses going to a stand alone heater, that in our 1984 motorhome is located under the couch and also to the waterheater. These hoses could have leaks anywhere along its length including at the connections or shut off valves. The heater also has a small heater core that could have a leak.
Gunter
1984 Motorhome 345
gunner is offline   Reply With Quote
Old 01-01-2008, 12:26 PM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
A 98 will have the plastic intake, and plastic intake gaskets. It could be seeping into the "combustion chamber area" of the intake, and burning it.
If you perform this repair yourself (if that's what's leaking), there is a pot metal fitting that has a heater hose quick-connected to it. That fitting tends to snap off when you mess with it, so be careful.
Change is inevitable, except from a vending machine
AIR#2611
Antifreeze question jcf48 Winterizing, Storage, Carports & Covers 15 11-01-2006 07:32 AM
Old pink antifreeze Bing-Bing Fresh Water Systems 4 08-06-2006 02:29 PM
Mystery Black Water Tank Leakage Howard Lefkowitz Classic Motorhomes 2 06-06-2006 02:54 PM
Antifreeze... yuck! Toasty's Dad Winterizing, Storage, Carports & Covers 34 04-24-2006 08:56 PM
Battery leakage ???? Kistler Our Community 1 05-09-2003 04:17 PM
