Old 12-30-2005, 04:49 PM   #1
Alternator output jumping
Hey Folks,
the output on my 79 Excella keeps jumping. When I start it, it's OK, but after running for a while, it starts jumping up to 17 volts... the lights flicker, and the fuse to the dash blows. Any thoughts?
Thanks, Sebastian
Sebastian DeWitt is offline   Reply With Quote
Old 12-30-2005, 05:43 PM   #2
Well Preserved
overlander63's Avatar
Colfax , North Carolina
Sounds like either the alternator is about to take the big crappolla, or you have an intermittent connection. You can take your MoHo to your favorite garage, and ask them to check the alternator.
Intelligence is learning from your mistakes. Wisdom is learning from others' mistakes.
Old 12-30-2005, 07:27 PM   #3
lewster's Avatar
Marco Island, FL , Hood River, OR
Sebastian,
It sounds like the voltage regulator section of your alternator is bad or well on the way. That is what controls the output voltage of your alternator. Also, the rectifier diodes might need to be replaced if they are a separate component and not integrated into the alternator. Any good garage or even a reputable tire center can usually tell by connecting a nifty little gizmo to your battery that checks your alternator output,
Also, if you get a new alternator, be ready for a new battery as well, 'cause 17 volts will fry most lead-acid types.
Lew Farber -RVIA Nationally Certified Master Tech.... MASTER TECH RV SYSTEMS, INC.
AM SOLAR SALES & INSTALLATIONS ...MAGNUM INVERTERS ...LIFELINE BATTERIES
NO MORE AIRSTREAM.... NO MORE MEMBERSHIPS....BUT I'M STILL AROUND!
lewster is online now   Reply With Quote
Old 12-30-2005, 09:57 PM   #4
Tinsel Loaf's Avatar
If it is not a bad connection (most likely not) cut your losses and replace the alternator and regulator. Cheaper in the longrun. End ‘O’ problem.
Tinsel Loaf is offline   Reply With Quote
Old 12-31-2005, 04:04 PM   #5
AIRFORUMS # 005
ALANSD's Avatar
1966 26' Overlander
North , Georgia
Send a message via Yahoo to ALANSD
I highly recommend a higher amp rated alternator if you do replace yours. If it is a stock alt its probably 60-70 amps, and a 135 will slide right in and do a better job overall for you. I replaced mine with one from www.4alterstart.com, and used their solid cased aluminum heat resistant starter. I have been very satisfied with both items for quite some time.
I would agree that unless you have a loose connection, your voltage reg is shot, and you should replace the alt at the same time.
Heat kills our alts and starters under that doghouse.
1966 Overlander Twin w/bunk 2000 Ford Excursion LTD V10
Please visit our blog:
OUR AIRSTREAM PASSION! BLOG
Old 01-01-2006, 08:10 AM   #6
1985 34.5' Airstream 345
Marietta , Georgia
Send a message via MSN to 85/345
I would start with the voltage regulator, it is the cheapest and easiest part to replace, if I remember correctly cost less than $20 and you can replace it in about ten minutes. I also agree with Alan about using a higher amp alternator.
85/345 is offline   Reply With Quote
Old 01-02-2006, 04:58 PM   #7
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
I agree on checking/replacing the regulator first. It's bolted to the top of the radiator housing. If that's not it then consider removing the alternator and taking it to AutoZone (or similar) as most of these places will test alternators for free. If you need a new one then you're already there.
Like Alan and I also run a higher amp alternator on our 345. It comes in handy then the kids are playing PS2 on the TV and I want to use the inverter instead of firing up the generator.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
It is here! Well, almost here... 1973 Ambassador Pschoerrn 1970 -1973 Ambassador 10 05-20-2005 02:56 PM
Bulkhead Structural Value 69Ambassador General Interior Topics 24 03-21-2004 07:43 AM
Vintage Airstream Club 3rd Annual Rocky Mountain Rally InsideOut WBCCI Rallies & Events 76 10-24-2003 12:54 AM
Airstream or I don't think so... canny_banjo_man Off Topic Forum 11 08-11-2003 01:03 AM
Doorbell Craig 1978 Excella 28 04-03-2003 06:59 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
