Old 10-18-2003, 07:26 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Alternator fun and games
A beautiful day here in Atlanta. I crawled under my MH after pulling the dog house covers off, and putting some light over the work area. I had disconnected the battery, pulled the old alternator, and attached the spacer to the new one, then tried unsuccesfully for about two hours to thread the bolt/line up the new alt. and mount it.
Sitting on the ground behind the curb side tire between the steering damper and radiator support and not being able to thread the bolt in. My new neighbors heard some choice epithets.
And I was out of beer besides!!
After major back/leg cramps, I finally managed to get the end of the bolt to catch, then the unit got stuck so I couldn't plug the wires in! It seemed to be wedged in too tight to move. I loosened the bolt again, no luck, had to pull it off all the way. By this time it was getting dark and the mosquitos decided I looked like dinner.
Any great ideas to make this job next weekend a bit easier?
I have done a few alternators in the past never had so much trouble fitting it. Oh yeah its a Delco exactly like what I pulled off but 135amp version. Also-- think a new battery wire is a good idea? The one on there doesn't look too dried out...
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-18-2003, 07:45 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
alan
you are not using enough "lubrication"!
quote: "And I was out of beer besides!!"
john
you call them ferrets, i call them weasels.
Old 10-18-2003, 08:03 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Having been in the car biz for about 35 years I can relate to your pain. While I am not familliar with this powertrain package I have found many alternater mounting brackets have a threaded insert that MOVES when the mounting bolt is torqued up so as to eliminate play and provide a good ground. Try installing the bolt, sans alternater, and tapping the head end to push the insert back or forth to gain some clearance. Good Luck and have a cold one for me.
Tom Nugler is offline   Reply With Quote
Old 10-18-2003, 08:46 PM   #4
LOST , Hawaii
What size wire is on there now, 10 ga? You need at least 2 for an alternator that big.
Compare the length and case diameter and the position of the plug and the mounts on both alternators. The case halves will rotate to 4 different positions for different vehicles.
Is the top bracket on? Hang it from there first then line up the bottom hole. There are other holes in the head the same size, make sure you are getting the right one.
John
74Argosy24MH is offline   Reply With Quote
Old 10-18-2003, 10:13 PM   #5
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Alan, now you know why I PAY to have it done LOL! Albeit through the nose.
As an after thought, beer has been known to alter one's control of the lumbrical muscles of the hand phalanges. I would recommend using Michelob Ultra, which is low in carbs and since you may think you're drinking carbonated water, psychologically enhancing as well.
Astrodokk is offline   Reply With Quote
Old 10-19-2003, 06:30 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
John the case looks to be set up just like the one I took off. You say that I can take off the back and rotate it? ...if so it could make the plugs more accessible. I hung the tension-mount bolt first, but I was afraid I might strip it with all the movement to get the bottom one line up. A few sprays of wd-40 seemed to help get the bolt to start right.
Not sure what gauge wire is on there but I would bet it is not as thick as a 10 ga. The dealer sells a special cable cut to whatever length needed for 150 amp and over, if it makes sense to, I can order it as well. The battery cable goes to the junction box then to the isolator?
AIR #005
retired!
Old 10-19-2003, 06:36 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
here is the cable description
"100% New alternator power cable. This new four gauge commercial quality cable is 6 ft long and comes with crimped 5/16" copper terminals enclosed in heat shrink tubing. The entire cable is also covered with split loom to protect it against shorts. We require this cable on all alternators 150 amp and larger. This new cable can also increase amperage output and decrease resistance to the battery." $25.00
AIR #005
retired!
Old 10-19-2003, 06:58 AM   #8
LOST , Hawaii
You can rotate the case but don't take the back off or the springs and brushes will come out. Pull the 4 bolts holding the halves together, wiggle it a little to loosen it and rotate it to the position that works. The brushes are only about 1/4" wide so if you move it that far back they will come out. If they do it is only a straightened paper clip to reinstall so don't worry.
Check Autozone for battery cables, less than half that price but no heat shrink. Get some split loom tube and pocket the change. They should have them with lugs on each end.
I would put in the top mount bolt first. Look at where it was from the mark on the bracket. Tighten it so it is snug but you can still rotate the alternator. Make sure the spacer is right (or leave it a little loose) so it doesn't force the pivot bolt to misalign. Use the WD40 liberally and wire brush the threads if they need it. It has probably been a long time since this was removed. If you have some antisieze (or grease) smear it around inside the bottom alternator mount hole. All that contact between the bolt and aluminum makes a mess, I have seen those big long bolts twist right off. That is not fun.
John
Old 10-19-2003, 07:58 AM   #9
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i replaced mine from the top. i upgraded to a 100 amp .
i took the top bracket off and inserted altenator in the cavity and screwed the lower monting bolt in and tightened. installet top bracket then belt tightened and havent had to do any thing. took and hour. but if you are trying to install from the wheel well that should be a bit easyier. i would get someone to hold the altenator up from top side whilr you monkey with the bolt. lol
al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 10-20-2003, 07:04 AM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
seemed to be hard to reach from the top, but I will try to get my assistant (read spouse) to hold it while I screw in the bolt.
While at it I noticed a hose clamp or two that need replacement ..and the carb could stand another cleaning. and....
AIR #005
retired!
Old 10-20-2003, 07:39 AM   #11
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
If your having that much problem getting it back on you may need to loosen up the mounting bracket the bolt passes through. Might even neet to loosen the bracket the alternatoro tensions against. It may be slightly cocked to the bolt hole in the front of the head.
GM alternators usualy go on pretty easy. Something has to be out of alingnment.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-20-2003, 08:40 AM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
yeah I thought having the spacer tight was a good idea. Now that I have backed up a little I find a few other things that need attention anyway
AIR #005
retired!
Old 10-25-2003, 04:26 PM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks for the advice, leaving the spacer a bit loose and using lots of wd40, and some non locking lube on the bolt the alt went on this morning easily. Had some trouble reaching the wiring afterwards with my less than long arms, but all went well. Now 2 questions...
I replaced the wire from the alt to the isolator with a 4 ga. cable, and I want to know what is the relay(?) on the left of the photo for?
Connected to the isolator and then onward...
Is it in need of replacement now that I have a 135amp alt?
Also I am buying a new isolator as mine is a 95 amp. If I run it meanwhile wiht the 95 amp will it fry the isolator? Or should I bypas it for now, and run it with out.
I should have a 150 amp or higher rated isolator in a week or two. Thanks all.
( the yellow wire is the old wire to my rear air bag compressor that I have replaced)
AIR #005
retired!
Old 10-25-2003, 04:37 PM   #14
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally posted by ALANSD
... I want to know what is the relay(?) on the left of the photo for?
That's a fuse, probably 30 amps. No need to replace it, but good to know its there for future trouble shooting.
1991 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Over the hill in style - b-day blues Janet H Our Community 30 01-24-2012 05:22 AM
WBCCI participation smily WBCCI Forum 206 01-08-2006 07:50 PM
Rocky Mountain "Forum Rally" Info InsideOut Forum Rallies & Meet Ups 162 06-28-2003 03:56 PM
