Old 10-25-2003, 04:41 PM   #15
LOST , Hawaii
I want to know what is the relay
Looks more like a circuit breaker. How many wires, just the 2 cables? If it is a relay there should be at least one small wire for control.
If I run it meanwhile wiht the 95 amp will it fry the isolator?
As long as you don't drag the batteries down it won't take that much to recharge and shouldn't hurt the isolator. If you are worried move the battery (cable) that had the most use to the center terminal and the isolator will be out of that half of the circuit.
John
74Argosy24MH is offline   Reply With Quote
Old 10-25-2003, 04:50 PM   #16
dinoburb's Avatar
1982 34' Limited
Tidewater , Virginia
ALANSD,
The item is a circuit breaker as John said. It is probably a self-resetting breaker. I would check the amperage rating so you know what is considered an overload by the original installer. If you are increasing the output of the alternator and you are increasing the carrying capacity of the wiring; it stands to reason the CB might be too low a rating and cause problems of its own. Never hurts to check!!
Take care.
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 10-25-2003, 05:08 PM   #17
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
muchas gracias mi amigos. Of course I want to start her up and run it and see how I did, I just didi not want to fry the isolator. I will try disconnecting the coach battery before I do that as it is on the list to be replaced.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-26-2003, 09:26 AM   #18
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
not to worry alan. you dont need to replace any thing . the cb is a fifty and it will trip before you fry the isolator. the fact you inslalled a 150 amp alt doesnt mean you will generate 150 amps
if your batterys go dead or short then you might be in trouble the alt will try to pick up the load and fry the iso and wiring. i loked at a 63 310 that had the starter cable short to the frame and it made a mess, but didnt kill the alt. the cb should have tripped but didnt.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 10-26-2003, 01:04 PM   #19
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Well I cranked 'er up today and the voltage meter was smiling at me 14+ volts with every light/radio/signal/etc on. Great!
I am looking at getting a 200 amp load isolator from a friend, so I hope to get that on in a week or so.
Now I can get back to playing with the rear air bags.
AIR #005
retired!
Over the hill in style - b-day blues Janet H Our Community 30 01-24-2012 05:22 AM
WBCCI participation smily WBCCI Forum 206 01-08-2006 07:50 PM
Rocky Mountain "Forum Rally" Info InsideOut Forum Rallies & Meet Ups 162 06-28-2003 03:56 PM
