Old 08-10-2018, 06:11 AM   #1
West Chester , Ohio
Alternator belt
Ok...1984 270 with a now new alternator, new pulley 2.5in, new belt, and cleaned drive pulleys. The belt has broken 2x after non-stop squeaking and significant heat. Silent belt when alternator harness is unplugged (no load). Checked pulley alignment and looks perfect. Regularly checking belt tension and is tight but not too tight...I am using NAPA belts. What am I missing here?
Kvsterling is offline   Reply With Quote
Old 08-10-2018, 07:51 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Do you have an electrical short on the output of the alternator? One way that could happen is you have one or more dead batteries .....
Old 08-10-2018, 08:49 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Does the belt youíre using fit the drive pulley? If the belt is too narrow it will drop onto the bottom of the pulley instead of riding on the shoulders of the ďVĒ. This will cause slippage = heat = damage = breakage.
Just throwing that out there.
Old 08-10-2018, 09:32 AM   #4
West Chester , Ohio
Using Napa part xl 7465. Top of belt is flush with edge of all pulleys. Part look up says this is right part number...
Old 08-10-2018, 09:44 AM   #5
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
Recheck your electrical connections, disconnect and then see if Alt spins smoothly, sounds like the Alt is "locked" when energized.
vintagemotor is offline   Reply With Quote
Old 08-10-2018, 12:17 PM   #6
West Chester , Ohio
When disconnected, it does spin smoothly with no belt squeak. Itís only squeaking when itís under a load trying to charge
Old 08-10-2018, 12:36 PM   #7
West Chester , Ohio
What mechanism regulates the Amps that the alternator produces? Maybe I should check that for proper function? I have a newish red top battery for chassis and checked out good
Old 08-10-2018, 01:42 PM   #8
Half a Rivet Short
Hi
An alternator has a voltage regulator on it that limits the voltage it puts out. The current is limited by the resistance of the windings. If you try to run one into a short ... it'll put out a lot of current .. A multimeter will tell you if the alternator is putting out the right voltage. It also will tell you if your batteries are at some crazy low voltage.
Old 08-10-2018, 02:31 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
V belt pulleys CAN wear out, but it takes a LOT of use to do that, usually hundreds of thousands of miles.
You might try one size wider belt just for kicks. I have done that with worn pulleys with great success.
I just donít believe that a typical alternator can be loaded up enough to snap belts.... something else is up in my opinion..... maybe your Napa got hold of a bad batch?
Old 08-10-2018, 02:32 PM   #10
Las Vegas , Nevada
Hi
and when the alternator dies, it usually takes the VR with it. Listen to Bob!
Old 08-10-2018, 02:41 PM   #11
West Chester , Ohio
Thanks bob, the alternator that was replaced tested putting out almost 15v. I have not checked the new one but maybe there is some electrical gremlins outside of my alternator hardware and there is nothing wrong with the belt...
Old 08-10-2018, 04:08 PM   #12
West Chester , Ohio
Iím going to try a larger belt and battery check. This week the belt broke with a new Napa belt on a new pulley mounted to a new alternator. It squeaked non stop for about 20 miles then failed with the heat build up. The rubber on sides of the belt was slick and partially melted
Old 08-10-2018, 04:10 PM   #13
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Did you ever think that it maybe the water pump ???
bobmiller1 is offline   Reply With Quote
Old 08-11-2018, 09:11 AM   #14
Half a Rivet Short
Hi
Continuing to run into what likely is a fault in the electrical system is a very good way to do a *lot* of damage to the electrical system. The cheapest part of it would be burning out the new alternator. Frying this and that downstream in the system simply adds to the bill. Worst case is probably a fire. Having a fire in an RV is no fun at all. Having that when moving 60+ mph down the road .... yikes !!!
Alternator Belt Replacment Fin4 Argosy Motorhomes 7 08-06-2018 04:54 AM
Serpentine Belt Question -'92 454 - HELP fangthorpe Mechanics Corner - Engines, Transmission & More... 17 07-25-2010 10:26 AM
Seat belt/shoulder harness options guy99 Airstream Motorhome Forums 16 06-26-2004 06:59 PM
ID'ing a Model by the Belt Line styling jaco Airstream Trailer Forums 5 02-25-2004 01:06 PM
Belt replacement on 454 Gas Classic AccessMaster Airstream Motorhome Forums 12 05-03-2003 12:31 AM
