Old 08-12-2018, 07:30 AM   #15
West Chester , Ohio
So the voltage regulator was bad on the 2-week old alternator! Replaced it under warranty and upgraded to 94A alternator. So far the belt squeak is gone and voltage gauge reads normal. We had a full system check (coach) by RV shop and everything checked out. 2 fire extinguishers on board in case
Kvsterling is offline   Reply With Quote
Old 08-13-2018, 06:02 AM   #16
West Chester , Ohio
Regarding the well known 454 alternator belt issues, I was reading the chassis service manual. Found that the alternator is to have a higher belt tension than the ac or PS belts. It is also to be re-tensioned after 30 minutes/15 Miles of driving, 8 hrs/240mi, and re-tightened every 200 hr/6000mi. I confess I did not know this procedure and may have been part of my belt failure experience. I will be checking water pump bearing situation this week
Alternator Belt Replacment Fin4 Argosy Motorhomes 7 08-06-2018 04:54 AM
Serpentine Belt Question -'92 454 - HELP fangthorpe Mechanics Corner - Engines, Transmission & More... 17 07-25-2010 10:26 AM
Seat belt/shoulder harness options guy99 Airstream Motorhome Forums 16 06-26-2004 06:59 PM
ID'ing a Model by the Belt Line styling jaco Airstream Trailer Forums 5 02-25-2004 01:06 PM
Belt replacement on 454 Gas Classic AccessMaster Airstream Motorhome Forums 12 05-03-2003 12:31 AM
