Old 12-15-2006, 07:52 PM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
From looking at your photos, it looks like the alternator is indeed under the bracket with the solenoid on it. From what little I can see of it, it is probably a 105 amp alternator. The amperage should be stamped on one of the mounting ears of the alternator. I would try to remove that bracket to get at the alternator--a silly question, does the alternator have a seperate belt, and is it there?
Also, a wire going from power to ground would not be conducive to proper electrical operation, try removing the "ground" wire, and see if you voltages improve, although I would think it would have fried off something somewhere if it was indeed a ground with all the hot wires with it.
Old 12-15-2006, 09:16 PM   #16
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
It appears that your isolator has been replaced with a relay. I have the same situation on mine 1984 MH.
Here's the thread where all of this is discussed. You might also want to try a search as there are other threads which discuss replacing the isolator with a relay.
http://www.airforums.com/forum...ue-17980.html?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
