Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 12-01-2003, 11:18 AM   #1
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Allison Transmission ???
Here is a question for those of you that are big into the GM stuff.
If I had the $$ to do it, what model Allison transmission would bolt up to my 454 block? And are the computers divorced from the engine systems so it can be installed as an add on to a normally aspirated motor?
This is the only part of the drive train I have not replaced and I figured if I start saving now I will have the money and the info when the time comes to do it right. Who knows if I have the info the opportunity may present itself and I will just "have to" do it.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 12-01-2003, 11:33 AM   #2
dinoburb
dinoburb's Avatar
Profile:  1982 34' Limited
Tidewater , Virginia
Not Allison But . . .
Hi newkid64,
The Allison might be the BEST transmission currently available for the GM world but cost and availibility might be prohibitive.
An alternative would be the 4L80E transmission which is a modernized version of the TH-400. Robust and expensive. However, there are folks out there who provide connection kits to utilize the advantages of the 4L80E in an older carbureted (non-computerized) engine. (DO NOT confuse this transmission with the much less robust 4L60E!!!)
The biggest advantage is availibility. Cost would be less than the Allison but significantly higher than the TH-400. It would bolt up to the 454.
Hope this helps some.
Take care,
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 12-01-2003, 12:00 PM   #3
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Most GM have a single ECM that controls both Transmission and engine. The reason is they can adjust the shift points to match engine load easier.
It would be a very expensive conversion. The stand alone computer conversion for the 4l60 and 4l80 are $800. I would expect about the same for the new allison. THen there is the price of the transmission.
Now an older Alison might not be a hard swap and may be a little cheaper over all. Most front engine school busses run Allison autos and have for 10 or so years. What I don't know is if the Industrail engine has the same transmission bolt pattern as the conventional engine like the 454.
Honestly I think the better and easier alterantive would be keep the TH400 and put a Gear vendors or simular overdrive on it.
TH400 is one tought tranny. It's also not very expensive to rebuild. It can be back yard rebuilt by a good shadtree. I have rebuilt TH350's and it was much easier then I thought it was going to be. It was also a LOT cheaper then you may want to know. Parts for a complete rebuild including a reman converter is $125-150 range. I would expect the TH400 to be about the same.
I'm looking for a Overdrive for my Burb right now Same basic set up as your MH 454 TH400. Just missed one for $400 complete. Only thing I would have to do is shorten the drive shaft and I would be darn tempted to try that myself. Couse the Drive shaft shop up the road will shorten a shaft for $40 and ballance it.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 12-01-2003, 12:01 PM   #4
thenewkid64
Just a member
Images: 21
I know about the weakling 4L60E and I will stay away from it. I am attempting to get a one piece transmission with built in OD to help make my new motor last longer and increase my MPG. I already have sunk a bunch of $$ in the coach, if I am going to replace the transmission I might as well go with one that is built to take to abuse. If I were to bolt on a Gear Vendors it will cost 2500 or so to do . This assumes that the 3 speed I have is good. If I need to replace it too I can add at the least a another 1500. So I figure if I can get the Allison and not have a franken-transmission for about 4 K I am in an equal position but without a possible weak link in the t-400.
Brett G
Old 12-01-2003, 12:07 PM   #5
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Hook up with your local Junk yard. Let them know your looking and they can keep an eye out for wrecks with that tranny. If they have it presold they can justify paying more for a low mile total. In a year or two I would bet you could get a low mile Allison for around $800.
1959 22' Caravanner
Atlanta, GA
Old 12-01-2003, 12:54 PM   #6
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Although I agree for this particular application a 4l80e is a better choice than the 4l60e, I have to say, I have over 75k on my 4l60e and at least half those miles have been towing a bunch of weight or drag racing. I think beyond the mechanicals in it, if it's taken care of, (and kept cool) and not driven on like it was stolen, the tranny is a good little tranny, not by any means good for a motorhome. Keep in my they also used the 4l60e trans in the 2000 Silverado. It's not a bad trans, but I will agree that the 4l80e trans is a more meaty tranny in comaprison to the 4l60e.
Eric
Old 12-01-2003, 01:32 PM   #7
thenewkid64
Just a member
Images: 21
Eric,
I do not speak from experience on the 4L60E but I have been told if it were not for that transmission many of the small shops would go belly up. Some of it may be the unit is being abused, or that it is marginal for the application. I would not trust it for my purposes in a MH chassis. I will agree however that with proper maintenance and proper temp control that any transmission will work well. I just want to be able to use it with normal maintenance. I already spend enough time under my cars and the MH I do not wish to add to the list by having a transmission that I would personally worry about. That is why I am looking at an Allison. I would upgrade when the time came, or I can stay with the good old T400 and at the least know I have a unit that is up to the task for another 50K miles or more.
Brett G
Old 12-01-2003, 01:40 PM   #8
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Brett, these guys should be able to answer all your questions: Suncoast I hear tell they can make an Allison "Bulletproof", unlimited HP and torque ratings.
There is also a company that builds 4L80E's up for racing or other HD applications. They have a "manual" version of the 4L80E called a Quadzilla
If an Allison doesn't fit a 454, you can always go to an 8.1L crate motor.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 12-01-2003, 01:52 PM   #9
Silvertwinkie
Aluminut
I hear ya Brett. I sure would love to install an Allision trans in my Impala!
I agree the 4l60e in a motorhome is a bit weak, and trust me, being under my cars all the time I too can very much appreciate installing once and not worrying about it.
Best of luck on the mod!
Eric
