Old 03-12-2015, 12:50 PM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Allison at545
Does anyone know how much fluid to add to the spec for the tranny cooler on an Allison at545. The tranny holds 5ga but I dont know how much more to add for the stock cooler. Its hard getting an accurate reading on the dip stick. Many thanks for the info.
Mike
mayco is offline   Reply With Quote
Old 03-12-2015, 03:49 PM   #2
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Mike
I check mine with the engine running in neutral, Seems to work for me mine is hard to read to. Here is a page from my Allison handbook
Name:	Allison oil check.jpg
shepherd57 is offline   Reply With Quote
Old 03-12-2015, 06:10 PM   #3
mayco's Avatar
Thats a nice sheet.....ill save that. Ill get it out here in the next few days and get her up to temp and look again. Specs say five gallons with the standard oil pan, a lityle under four ga with the shallow pan. Im assumed this has the standard pan but Ill measure that tomorrow. Little over 11" from center line for standard pan. That dip stick gets oil trails up the sides and with clean fluid its hard for me to get a good reading on the actual level. Thanks for that sheet, very helpful.
Mike
Old 03-17-2015, 07:30 PM   #4
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
my oh my.. You have a 545? The po had a 545 installed in my 'silver bullet'. Was a good transmission, but couldn't take much more input torque than the stock(weak) 454.
Mine died and I replaced it with a 4L80e. Turned out the installers of the 545 missed the hole in the crank with the tit of the torque converter is the reason for the failure.
I'm not sure I'm all that happy with the 4L80e. But it is working with a 496cid motor with a lot more torque then the 545 was make to handle.
choctawmel is offline   Reply With Quote
Old 03-17-2015, 07:54 PM   #5
shepherd57's Avatar
Lindsay , Ontario
I have the 545 in my Isuzu powered 32.5 it is a good trans but it has no lockup converter and no overdrive. I am thinking about putting in an Allison 5 speed with the lockup converter. It will bolt right in and will need a stand alone wiring harness and Allison TCM to make it all work
Old 03-18-2015, 09:03 PM   #6
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
In your application I'd stay with the 545 and change the rear end gear to get the same effect as an overdrive. The 545 has so many clutches/plates it is better than a 'lock up' convertor.
I should/would have done that except I increased the input torque well above the max input for the 545
Old 03-19-2015, 02:17 PM   #7
mayco's Avatar
If you are willing to forgive my mechanical ignorance, could you explain what all gets changed out when changing the gear ratio in the differential? In our case obviously we would want to reduce rpms at cruising speed to reduce wear and tear on the motor. Is the gear change isolated to the ring and pinion gears or all the gears in the rear end? I would assume while having it tore down you would replace all bearings and such. What type of reduction in rpms could be accomplished while still having reasonable lower end torque? Im happy driving at 60-65 mph but 2700+ rpms has always seemed pretty high to me. I would never try to open up the rear end myself, I would pay to have it done. What type of cost are we talking about......ball park? Ive heard and read very good things about my at545 and dont think I would consider messing with it. Especially since I dont have the mechanical abilities to do the work myself.
Old 03-19-2015, 06:20 PM   #8
shepherd57's Avatar
Lindsay , Ontario
Mike
You could change the rear end ratio to a 4.10 it would have to be done by a rear end shop
choctawmel
I think you will find that the Allison 2000 series 5 speed has more than enough strenght to handle what a 454 can put out they are used behind the Duramax diesel in med duty trucks to 30.000 lbs
Allison-Transmission-2000-Series-Spec-Sheet.pdf
Calling all Duramax/Allison owners Silvertwinkie Tow Vehicles 31 10-04-2004 05:19 AM
Where is the Speed Sensor? (Allison Tranny Error) Griffin Mechanics Corner - Engines, Transmission & More... 4 12-16-2003 04:57 PM
Allison Transmission ??? thenewkid64 Mechanics Corner - Engines, Transmission & More... 8 12-01-2003 01:52 PM
Duramax-Allison Pahaska Tow Vehicles 34 11-23-2003 10:55 PM
Allison auto transmission O/D lockout davidz71 Tow Vehicles 0 01-20-2003 10:28 AM
