Old 07-09-2005, 05:52 AM   #1
Nick Danger's Avatar
1989 37' Airstream 370
Beverly Hills , Florida
Thumbs up Airbag replacement
I need to replace the airbags in my 1989 370LE. I've just emailed Airstream for the manufacturers name, part numbers and price.
I'd like to do the work myself, but am clueless as to where to begin. Does anyone have any documentation, tech manual info or anything else regarding removal/install they would share with me? Also, if someone could explain how the airbag system works and where the various componnents are located would be helpful. I realize I may have to take it to a dealer to get the work done, but I'd like to try it first.
Any hellp is gretaly appreciated.
Nick Danger, Third Eye
Nick Danger is offline   Reply With Quote
Old 07-09-2005, 06:51 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Nick,
Are you doing the front or rear bags? The process is simple in either case, but it is different.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-09-2005, 07:49 AM   #3
I want to do both.
Old 07-09-2005, 08:28 AM   #4
Cedars's Avatar
1983 31' Excella
Waterloo , Iowa
But, WHY do you need to replace your airbags?
Be prepared to pay a bundle for them. Each!
Also be aware, in case of bag deployment, often times an insurance company will... how to put this? If you install new bags for any reason, (and "you" means you, personally, not a garage) and during an accident they fail to function, the insurance will not cover injuries caused by that, or the cost of installing new ones!
Elizabeth in Iowa
The carpeting is gone! The carpeting is gone! Long live the cork floor!
Cedars is offline   Reply With Quote
Old 07-09-2005, 09:27 AM   #5
Because I had an Airstream dealer look at them and he said they need to be replaced.
Old 07-09-2005, 09:55 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Elizabeth in Iowa
Elizabeth....they mean the SUSPENSION airbags not the safety ones
Aaron
WBCCI #XXXX AIR #2495
Old 07-09-2005, 10:32 AM   #7
Bob66789's Avatar
New Airbags
Hello Nick,
I purchased my rear airbags from Fleetpride. The part number is W01-358-5405. They run about $120 each. The front airbags can be found at Camper's Choice for $72.95. This includes both bags and extension kit.
The part number is S047. I will pm you with install instructions.
Bob66789 is offline   Reply With Quote
Old 07-09-2005, 10:34 AM   #8
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by Nick Danger
I need to replace the airbags in my 1989 370LE....I'd like to do the work myself, but am clueless as to where to begin. Does anyone have any documentation, tech manual info or anything else regarding removal/install they would share with me? Also, if someone could explain how the airbag system works and where the various componnents are located would be helpful. I realize I may have to take it to a dealer to get the work done, but I'd like to try it first....
Nick:
Don't know how much of the Chevy P-30 technology transfers to your Gillig chassis, but for the Front Bag change-out check out this thread.
http://www.airforums.com/forum...t=front+airbag
I did the fronts, and would do it again.
Rear bag system here:
http://www.airforums.com/forum...ghlight=airbag
and here:
The operation of the leveling jacks will temporarily deflate your rear airbags since the sensor for the air bag auto fill is actually mounted on the tag axel (again, I am talking P-30 frames and tag mounts). When the rear end is "lifted" by the leveling jacks the tag angle increases, giving the main rear air bag control valves an indication the rear suspension bags have too much pressure, and will then bleed ALL of the pressure out of the air bags.
A bit of movement (and a full volume tank) will bring things back to normal. When the main suspension bags are totally deflated my main axle support is actually resting on the frame.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 07-09-2005, 10:44 AM   #9
Cedars's Avatar
1983 31' Excella
Waterloo , Iowa
Aaron
Duh, do I feel dumb! (Hitting self on forehead with heel of hand!)
SUSPENSION airbags are easy to replace! No big deal there! While I haven't actually done it myself, I have handed the tools to the mechanic..... VBG!!
Elizabth in Iowa
Old 07-09-2005, 12:31 PM   #10
Post
Many thanks to all of you for your help. I'll verify the Part numbers with Airsteam if they can.
I'll also check out the threads.
Thanks again...........
Old 07-09-2005, 04:16 PM   #11
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
lots of luck . airstream will give you their numbers. and their inflated prices. that has been my experience.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 07-09-2005, 08:23 PM   #12
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Try Fleetpride for your chassis as well. Also, if you being in your old bags to any decent truck parts shop they can match them for you. I'm always amazed at how these guys know "exactly" what it I I drop on their counter - scary, but cheaper than a dealer or the factory
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 07-09-2005, 08:46 PM   #13
Thanks for the tips. I haven't been able to access Fleetpride's web site. I keep getting a message that the site is not available. I'll try again later.
Old 07-14-2005, 08:53 PM   #14
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I went to <macsspring.com> Thay did Me good
alfalsetto is offline   Reply With Quote
Ventline screen replacement BB 55 Bubble Roof Vents, Skylights & Fans 1 10-29-2011 11:53 AM
Replacement issues wander'n Refrigerators 0 10-11-2011 06:25 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Replacement Gold Cone Light for '58 mello mike Lights - Interior & Exterior 7 03-17-2011 10:56 PM
