Old 03-19-2006, 09:43 AM   #29
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Yep. Just get a good vise grip pliars and clamp onto the old bags and screw them out through the hole in the bottom of the spring. Worked good for me. I even carry a spare one on the road now. All I need is the vise grip.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 03-19-2006, 10:20 AM   #30
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by swebster
balrgn,
Good news...you don't need to take apart the A frame to install bags. The old bags come out the hole in the lower control arm...and believe it or not, with enough dish soap, the new ones slide up through the same hole.
NO WAY! That is too kool... Hmmmmmm where did you say you got em?
I darn near lost a toe replacing my 62 Chevy's springs!
http://www.balrgn.com/stuff/62-1.jpg
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-19-2006, 07:13 PM   #31
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Yeah, it's actually one of the easier projects to do on the Moho. Here is a link to the bags at CW (http://www.campingworld.com/browse/p...=1745&src=SRQB)
Most local RV dealers will stock them too.
Sweet ride! I definately need to stop in on you when I'm in Rye this summer. I'll bring the 345 and we'll take a picture of Peanut next to it.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 03-20-2006, 03:51 AM   #32
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
I'll look into the link! Thanks
By all means stop in ! I have room for a few more rigs. If you interested, we have courtesy parking @ our camp in the mountains too. PM and let me know when your in the area.
www.balrgn.com
Old 03-20-2006, 08:33 AM   #33
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by Chuckles
AlanSD, I saw your cockpit/doghouse make over in one of the other threads, very nice indeed. I am hoping to do something similar but need to replace the front passenger side AC trim and find the side mouldings as these are missing. (Later type dash with all the lights in a row!)
I gather there are some bolts that hold the doghouse down. I cannot find these probably buried under carpet/underlay. I want to remove the doghouse to attend to engine "front-end-bits-n-pieces". Do you know where about I start looking? Along the bottom, edges or across the top?
the bolts are up top on the leading edge of the doghouse after you remove the radio/stereo mount. You can see them then. The whole affair pulls off and you can get to the front area of the engine.Thanks for the compliment, the front area looks much cleaner and is a lot quieter also.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-20-2006, 04:06 PM   #34
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Thnaks for the info, Should be in by weeks end!
www.balrgn.com
Old 03-27-2006, 05:57 AM   #35
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
balrgn,
Air Bag, or what was lfet of them came out the spring gap, with needle nose vise grips. It does not look possilbe to cram the new ones in the existing hole........
www.balrgn.com
Old 03-27-2006, 06:34 AM   #36
87MH's Avatar
1978 31' Sovereign
Images: 292
How to....
Check out reply #16 in this thread
http://www.airforums.com/forum...eath-9121.html
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 03-29-2006, 09:53 AM   #37
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Is it worth the risk?
Got the air bags, 3-1/2" outside diamater. Hole diameter = 2.0". Read up on instalation techniques. Drew a vacuum on the air bag with a schrader valve installed to hold compression. For me, it is not worth the risk of damage to the bag attempting to give it the ole Arthur Cram through the hole. Sooooooooooo New springs are on order, will have em tomorrow. $106
Looking for upper and lower ball joints. So far $75 each. Pay me now, or pay me later. I’ll bite the bullet and rebuild the front end….
www.balrgn.com
Old 03-29-2006, 12:14 PM   #38
Chuckles's Avatar
Iwerne Minster , Dorset. UK
Front Air bag squeeze!
Just a little tip.
I used cable ties instead of hose clips! I hope you call them the same... the plastic strap type thingy’s that some cops use instead of handcuffs!
Any way I removed the valve core, scrunched down the bag to a smaller size than the hole, pulled it tighter with the cable tie. Used one every inch or so, as need be.
Oiled up the bag with washing-up liquid and in it went. As you progress to each strap, simply snip with side cutters and you’re in.
My big mistake was to remove the top and bottom collars to help get the bag in the hole. Half way through inserting the bag I tried to fit the top collar back on… No way! It would not go on so that was left off in the end, so I expect to replace that bag in no time! The bottom one was easier and went back nicely.
I want next to fit 3 way solenoid valves and control the front and rear bags’ pressure remotely from the cab for a) adjusting for load, and b) a minor levelling adjustment before the jacks are used. The GMC had such a system that I believed worked well.
Chuck
PS Thanks AlanSD for the tip on the dog-house bolts. Looks like it’s carpet off time!
Chuckles is offline   Reply With Quote
Old 03-29-2006, 12:19 PM   #39
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Have fun friend! It will be worth it when its completed.
AIR #005
retired!
Old 03-29-2006, 12:22 PM   #40
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
have you found the ball joints yet? wonder if these guys would be helpful-
www.walkinvan.com
AIR #005
retired!
Old 03-29-2006, 12:44 PM   #41
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
www.walkinvan.com
Good link, thanks! I have not committed to Ball Joints just yet. Prices are ranging from $35 to $90... Looking into why.
This baby otta drive pretty sweet with these. I may go with Urethane bushings too while I have it apart...
Wait till ya see what the paint plan is (they make new polly rollers for primer)
www.balrgn.com
Old 03-30-2006, 03:02 PM   #42
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
In case your interested?
Removal of the spring is about 20 minutes worth of effort.
  1. Jack and support the frame, one side only
  2. Remove the tire
  3. Using a floor jack, lift the A-Frame at levelize the shock.
  4. Remover the lower shock mount, free shock from perch
  5. Remove the Front Stabilizer bar (2 bolts)
  6. Remove the cotter pin on the lower Ball Joint, remove the nut
  7. With a brass drift pin, strike the top of the ball joint (where the nut was)
  8. Slightly lower the jack, repeat until the taper breaks free
  9. If you have a dust cover on the Disc brake rotor ensure the A-Frame will pass by
  10. SLOWLY lower the jack, remove spring.
Clean everything!
Open Beer or beverage of choice and CELEBRATE!
Name:	Spring removed.jpg
www.balrgn.com
Ventline screen replacement BB 55 Bubble Roof Vents, Skylights & Fans 1 10-29-2011 11:53 AM
Replacement issues wander'n Refrigerators 0 10-11-2011 06:25 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Replacement Gold Cone Light for '58 mello mike Lights - Interior & Exterior 7 03-17-2011 10:56 PM
