Old 04-23-2012, 04:45 PM   #1
1995 36' Classic 36
Ludington , Michigan
Air in fuel system
Been chasing my tail for a couple of days. The Cummins has run beautifully and flawlessly since I bought the thing last August. The other day I started it up and it started idling rough then quit. I checked the lift pump pressure and found a bunch of air in the system. Turned out to be dried out O-rings on the Winn air/H2O purge system. It has a clear plastic pre pre filter with a screen in it. Kinda ironic that the system that purges air from the system was letting air in. I nugged it enough to start leaking while replacing the cartrage filter. I googled Winn Fuel Filters and found out its a pretty common problem. Just something to check next time you replace the cartrages. It's the kind of failure that will leave you on the side of the road.
Kota is offline   Reply With Quote
