Old 09-02-2008, 10:55 PM   #15
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Mustang, I think we are talking about the same guage. It needs to be connected between the air filter and the turbo, that way it reads air restriction, vacuum, caused by a blocked or partially blocked filter. The guage I have holds the maximum reading until manually reset. Gives real information on what's happening while going down the highway under load.
The wiring is always fun but I like to find how things were originally set up to work before I start redesigning things. Sometimes the designers really did have a good idea and it's the people between the designers and you that caused the problems.
As for my new challenge, while going in to get some fuel and propane today I got about two miles from home and the alternator froze. It was doing some not nice things to my new belts. I managed to loosen the belt adjustment to try to limp home without destroying the belts. The question now is it the alternator or the vacuum pump behind it that is frozen? Anyway I guess we all know what I'll be doing tomorrow.
Cheers, Dan
Temp/Air bags...few other questions.. swinginping Classic Motorhomes 4 02-15-2008 09:10 PM
Air Filter for Fantastic Fan thecatsandi Roof Vents, Skylights & Fans 9 06-16-2007 04:56 PM
HELP with alternator dorothywhitt Mechanics Corner - Engines, Transmission & More... 1 07-11-2006 12:44 PM
Armstrong AC air filter sander17 Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-12-2004 08:22 AM
Puzzling Onan Air Filter on 1995 Land Yacht scotta Airstream Motorhome Forums 1 08-20-2003 06:37 AM
