Old 05-23-2010, 12:07 PM   #29
All those mods look great!
I have a problem that maybe someone can help with...
I recently bought my '84 Classic 345 to California, and have to smog it to complete the registration.
I have the original Airfilter, with the Banks upper housing, but the canister intake is missing, and also I have no idea where the several small pipe should go...
Anyone got time to trace their pipes or anyone know where I can get a schematic?
This is what I am talking about...
Looks like there is a place for a pipe on the inner silver nipple... and the brown connector has a place for 2 or maybe 3 things to connect to... and on the rim of the filter there looks like a clip for 2 pipes...
Does anyone have the complete sytem tucked aside when you did the conversions?
Old 08-19-2011, 12:40 PM   #30
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Ok, if carb hat with single inlet is good, what about with dual inlet? Or is that just asking for trouble, trying to route two carb inlet hoses?
Dual Inlet Carb Hat Air Intake Plenum Supercharger | eBay
Old 08-22-2011, 06:09 AM   #31
projector's Avatar
1972 23' Safari
NSB , Florida
On mine there was barely enough room for one duct. The 4" duct is about the size of the carb inlet itself so I don't think a dual inlet would do much for you. I looks cool though.
projector is offline   Reply With Quote
Old 08-23-2011, 08:22 PM   #32
crazeevw's Avatar
When I finally get this beast home into my driveway, I'll start 'tearing things apart' to see what all I have. Was looking today through the engine access door on front of moho, and saw a 4" duct pipe coming from engine compartment to the front grill. Only been inside doghouse once, and didn't think to pay attention as to what was under that Banks Air Filter cover. Know that current owner had the Banks Power Pack installed, and his comment was 'What a difference'
Old 12-30-2012, 10:44 AM   #33
Projector,
I really like how you made this mod. I'm curious as to whether you have any issues cleaning/replacing the air filter, and have you found that you do it less or more often because of the location?
Originally Posted by projector View Post
Here's what I ended up with. I made an aluminum bracket with a 4" tube welded on for the duct and filter to mount to. Okay I didn't make it but instead used the talent in the metal shop at work. The bracket has a bend in it to shield debri and water from the front tire. The majority of the debri doesn't make it that far forward but this should help.
Here's the part before paint.
Attachment 101511 Attachment 101512
Here's the instalation. To attach it to a 1x2 frame crossmember I drilled and tapped for 4 1/4-20 screws.
Attachment 101513 Attachment 101514
Here's the top. I added a vent for the crank case. I couldn't find one that fit the smaller hole in the valve cover so I bought a new pcv grommet and a cheaper aftermarket vent that fit the inside diameter. And painted it black to match, of course. The only thing I may change is to shorten the duct to tighty it up a little.
Attachment 101515
Going for a ride it seems to make a big difference. It seems peppier and has better acceleration, not to mention the that wonderful sound of the 4 barrel kicking in. I used just less than half of the 6' duct that I bought. If anyone is interested the the left over piece, it is about 38" long and I'll sell if for half what I paid plus shipping. Let me know and thanks.
bkahler is online now   Reply With Quote
Old 12-30-2012, 11:00 AM   #34
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Originally Posted by bkahler View Post
Projector,
How does heavy rain affect the driveability; does the air cleaner element gets wet and doesn't allow air flow or cause any other issue?
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 12-30-2012, 11:23 AM   #35
2003 25' Safari
Riverside , California
An issue I see with your hat is it is very small and the air has to make a very tight turn to enter the carb this causes high turbulence and a marked decrease in potential performance.The length of the duct also makes a difference in flow vs going to a larger duct at that length.I have vanes in my intake track every where a tight radius has to be made.I have gained over 50lbft of torque with just airflow mods on my truck at cruise rpm.slowing down the air anywhere it has to make a turn will help also.That is why the oem air filter housings are as big as they are.
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 12-31-2012, 09:56 AM   #36
LimeyRich's Avatar
1988 34.5' Airstream 345
The eastern swamps , North Carolina
Air cleaner mods
Good useful thread guys! Glad to see it resurrected. Thanks for reposting those pics Glen.
I am temporarily running a 14"x4" spectre high flow air cleaner on top of my Holley 650cfm 4150, that combination has already helped gas mileage significantly, but it does nothing for the hot intake air problem. However I have had my eye on Glens Air cleaner mod for a long time. I intend to build Glens mod, with a short velocity stack inside, and run dual 4" intakes to each wheel well. That will be my next mod, after completing my 4L80e conversion. The transmission changeover should be wrapped up soon.
All the best! Have a Happy and prosperous New Year! Rich.
LimeyRich is offline   Reply With Quote
Old 01-03-2013, 10:48 AM   #37
I'm beginning to think this is the piece Dual port carb hat I want to use. I just to need to make sure I can route both hoses to the front or to the front wheel wells like Projector did.
Even though my Argosy is supposed to have both batteries located up front and center I'm going to relocate them to more sensible locations. I'm almost positive the coach battery will be relocated under the bed/couch in the back. Not sure about the engine battery but probably will relocate it to the left front wheel well.
Old 01-03-2013, 12:33 PM   #38
LimeyRich's Avatar
Glenns mod, modded for a 345 coach.
I am pretty well convinced that Glenn has been on track with his air cleaner mod. Furthermore he has been running it for a few years now.
Take the time to do a DIY job with very little expense and you'll be a happy camper.
I sourced my hose from Rockleer Woodworks and the upper and lower parts of the canister from Summit Racing. I added the body by wrapping about 4 layers of flashing aluminum and then cutting the hose opening. Sealed all with gasket maker and this system is then fronted with a reusable cone filter.
Performance gain was noticeable and has stood the test of time well.
Glenn's air cleaner is simple to build, and simple to mod for dual 4"intakes especially if you have a 345 coach. Adding a short velocity stack inside the box is easy, it will clean up the air flow over and into the carb, plus I have one sitting around currently doing nothing to justify it's upkeep. Because of the extra junk on my '88 345's engine there is almost no unobstructed room to the the front.
Going over the valve covers on each side and out into the wheel well looks like the ticket for me.
ooh, ooh, almost forgot, plus some nice flat black spray paint might make the setup look factory, to a casual peek!
That's my two cents.
All the best. Cheers!
Old 01-04-2013, 01:40 PM   #39
projector's Avatar
1972 23' Safari
NSB , Florida
I would have to say "less" because I haven't done either yet. It's location is easy enought to get to. It's also mounted high and forward enought that water isn't really an issue. It also is getting plenty of air.
thanks
Projector,
Old 01-04-2013, 04:13 PM   #40
thanks
Thanks for the info. I like the location you chose for the filter so I'll see about using the same location once I get motor back in the chassis.
Thanks!
Best toilet/shower cleaners willyd Cleaning, Stripping & Polishing 1 10-16-2008 07:42 AM
