Old 06-13-2014, 06:34 AM   #1
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Air Cleaner Retrofit
Ive never been impressed by the factory installation of the air filter on my 360.
Name:	ImageUploadedByAirstream Forums1402660866.487732.jpg
It is impossible to service properly without completely removing the canister which risks getting dirt into the induction tubing. You can loosen the mounting brackets and force it up on the rubber couplers to remove the cartridge but that risks dirt falling out of the pleated filter into the turbine inlet. I believe that was the cause of the impact damage on my turbo by the POs.
Name:	ImageUploadedByAirstream Forums1402660918.576128.jpg
The air intake tube was about 6 feet long and sucked the dustiest air possible from this 2' x 2' x 2' mystery box in the rear corner. There is a louvered 10" x 10" inlet on the rear corner. The box is "isolated" from the rear by rubber blankets. There are huge gaps that allow air from the engine compartment and rear cowling into the box where this huge 8" vacuum cleaner hose happily ingesting anything that enters. One disadvantage of a rear engine is that it is in the dirtiest, dustiest position possible.
I experimented by relocating the existing canister.
Name:	ImageUploadedByAirstream Forums1402661376.453332.jpg
Name:	ImageUploadedByAirstream Forums1402661441.892704.jpg
I ran it that way on our spring trip for about 3000 miles and was happy with the results. It wasn't sealed off from the engine compartment so not truly a cold air inlet but no worst than the original. It did free up space in the engine compartment to relocate the coach batteries to the rack. That really worked out well!
Name:	ImageUploadedByAirstream Forums1402661733.244934.jpg
After hours of research and searching I found an air cleaner that was perfect for the application. It's from a 2012 Freightliner M2. Its from Donaldson and uses the PowerCore axial flow filters. They boast 10x the efficiency over the pleated filters. Designed for 500 hp it should be overkill for the little 5.9L.
Name:	ImageUploadedByAirstream Forums1402662099.770098.jpg
The new configuration uses the existing 4" to 5" 90 degree elbow and 5" aluminum tube with a 5" to 7" hump connector and the Freightliner filter.
Name:	ImageUploadedByAirstream Forums1402662388.847101.jpg
I fabricated some baffling to seal off the air box and mounted the filter.
Name:	ImageUploadedByAirstream Forums1402662524.929526.jpg
View looking in through the air inlet opening.
Name:	ImageUploadedByAirstream Forums1402662549.130136.jpg
I'm very happy with the results. It's very easy to service through the side louvre. The filter design virtually eliminates the chance of getting dirt in the intake during service. The cartridges are $37 vs $70 for the stock cartridge. It has a safety filter to prevent FOD.
Air Dog is offline   Reply With Quote
Old 06-13-2014, 06:43 AM   #2
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
The airflow should much better than the original and the air source is 100% fresh air through the side vent. I'm expecting much less dust to enter the filter and colder air.
I also believe I got better airflow through the engine compartment for cooling by removing all of the obstructions of the stock system.
One other improvement was creating more clearance for servicing the oil filter. The stock installation squashed the rubber elbow off the turbo into the top of the filter. It created the possibility of getting dirt into the top of the oil filter during changes.
The original had 4 90 degree turns and about 7 feet of flex tubing.
I did have to enlarge the side inlet slightly to get the 13 inch diameter filter cartridge through it. The original louvre covers the hole but I'll fabricate a new one next week. I'll post an update.
Old 08-10-2014, 03:03 PM   #3
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Name:	ImageUploadedByAirstream Forums1407704196.400377.jpg
Name:	ImageUploadedByAirstream Forums1407704231.011355.jpg
Name:	ImageUploadedByAirstream Forums1407704260.621104.jpg
Old inlet in enlarged hole...
Name:	ImageUploadedByAirstream Forums1407704589.722136.jpg
Got er dun!
Last step was fabricating a new inlet louvre. I had to enlarge the opening about an inch to accommodate the air filter element. Changing filters is now a 10 minute job with easy access. The new axial flow filters make it nearly impossible to get dirt in the intake.
Colorado emissions test next week and then the fall trip.
need air cleaner advice Smoky Full-Timing, Winter Living & Workamping 3 07-22-2009 06:37 PM
Central Vacuum Cleaner Snadi Nu-Tone Appliances & Central Vac System 8 06-23-2005 06:29 AM
Carb cleaner Bill Resseau Mechanics Corner - Engines, Transmission & More... 4 04-30-2003 10:17 AM
