Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 09-09-2013, 12:31 PM   #61
kmamedia's Avatar
2002 26' Land Yacht 26
Seabrook , Texas
Might add A Giroscope in case you get into a Turbulance
kmamedia is offline   Reply With Quote
Old 09-09-2013, 04:02 PM   #62
A properly installed "air speed indicator" and a "sensitive altimeter" worked great for me.
They told you when you had a tail wind or head wind, and if you were climbing ever so slightly, so that you could regulate your speed accordingly.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-11-2013, 02:07 PM   #63
1995 36' Classic 36
Ludington , Michigan
My first trip in the AS was driving it from Seattle home to Colorado. Didn't really notice it in an unfamiliar vehicle but we had a nice steady 30 mph tail wind all the way. A few weeks later we drove it to Michigan with a nice steady tailwind. You can imagine our disappointment when we fought 40 to 50 mph gusty quartering headwinds all 1500 miles home.
I can't wait for the days when my travel days are not dictated by vacation from work.
Kota is offline   Reply With Quote
Old 09-24-2013, 05:27 PM   #64
1995 36' Classic 36
Fuel Pressure Gauge
Got everything ready to go for our fall trip when we got one of "those" family phone calls from Michigan. Ann had to travel back to be with her mother in the hospital. Figured I might as well get some projects completed. Found a place in the dash for the fuel pressure gauge. Its starting to look like the engineers panel in the spruce goose. Some day I'll make a new panel for it. Someday...
Name:	Fuel Pressure Gauge 004 (Large).jpg
ID:	196318   Click image for larger version
Name:	Fuel Pressure Gauge 005 (Large).jpg
Old 12-07-2015, 10:50 PM   #65
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Teleflex
Reviving an old thread here…..
Does anyone have a line on an OEM Air Suspension gauge for my '89 370???
Any thoughts on sources for repair of the existing unit??
Charly
streamquest is offline   Reply With Quote
Old 12-08-2015, 05:53 AM   #66
Charly,
I've been watching for Teleflex gauges on ebay for over two years and have not seen the air suspension gauge show up. However the one company that I know of that still deals in Teleflex gauges seems to list a price for one at $39.69 part number XLS50766-011. That doesn't mean it's available but it would be worth checking on.
Here's the page listing the Teleflex gauges.
And this is Custom Instrument Panels home page.
Hope this helps
1975 24' Argosy Motor Home
Old 12-08-2015, 08:22 AM   #67
I too have not seen one Charly. I am wondering if its a mechanical oil pressure gauge with a different face.
Good link Brad!
Old 12-08-2015, 08:42 AM   #68
Good link Brad!
The air suspension gauge I have is electronic and uses a transmitter similar to those used for the oil pressure gauges.
ID:	253528Click image for larger version
One thing to note. In the link I provided the gauge is listed as 0-150 psi mechanical. Mine is 0-120 psi and uses a transmitter. The part number on my gauge is 53679.
Steve, I thought you might find this page interesting. I don't necessarily like the looks but the process is interesting.
Old 12-08-2015, 08:57 AM   #69
Charly,
This isn't the same style but might work for you in a pinch.
Teleflex 0-150 psi gauge
Old 12-08-2015, 11:58 PM   #70
1936 20' Clipper
1947 22' Liner
Curtis Wright
Thanks!
Brad and Steve, you two are a better source of info than the internet!!
Thanks for the suggestions and sources. My 370 came with an aftermarket gauge attached below the dash to replace the apparently failed original (which was the 0-120 unit that Brad referenced that is evidently discontinued). Since this moho is largely unmolested from original, I'm trying to restore it back to stock wherever possible.
In the case of a 370 on the Gillig chassis, the suspension and parking brake are both dependent on air pressure. Was this "Air Suspension" gauge used on the much more widely produced 345's, 310's, etc.?? I don't recall seeing one on my 325 before rebuilding the dash several years ago. Just thinking about potential "gauge donors".
Thanks again,
Charly
Old 12-09-2015, 05:49 AM   #71
Probably because we've spent way to many hours searching for parts! And in my case more time searching than actually working on it
Are you 100% certain it's the gauge that is bad and not the sender? If I was a betting man I'd bet that the sender went bad and the PO just used a different gauge. Sometime in the near future I'll hook up my sender to see if I can determine what resistance values it uses. That should help ID what type of sender to look for.
Definitely don't throw away your old gauge until confirming it's actually bad.
I know my old 84 310 didn't have a suspension pressure gauge. The one I have came off an 86 345. Possibly 86 and newer has the gauge you're looking for.
I'll post back when I finally determine what type of sending unit is needed.
Old 12-11-2015, 12:28 AM   #72
1936 20' Clipper
1947 22' Liner
Curtis Wright
Brad,
I've been digging through the Gillig chassis manual which provides a lot of detail regarding the air system (fittings, lines, etc.), but no mention of a gauge. Same with the Airstream manual. Go figure.
There's also a warning light on the dash that goes out when the air pressure is satisfactory to provide e-brake power when underway, or to release the parking brake (same) to get underway. So there is definitely something sending info from somewhere.
I'll get further into this when business settles down a bit. I want to have my head in a good place before opening up the dash.
Charly
Old 12-25-2015, 02:44 PM   #73
I wonder if this would work Charly.... Oil pressure gauge, so runs from a sender, and reads to 90psi....
I think I might grab one and try it as a Fuel pressure gauge...
Teleflex Oil Pressure Gauge 0 90 PSI Part 54658 | eBay
Added this to my gauge setup(temporarily installed).
Innovate Fuel/Air gauge.
Old 12-25-2015, 04:57 PM   #74
The thing to watch for with any gauge is making sure you have the correct sending unit to work with it.
Just so happens I spent about an hour earlier today playing with a variety of the Teleflex gauges that I've been buying over the last few years. I've been lucky and managed to find the correct sending units for all of the temperature gauges I'm going to use (engine oil temp, engine coolant temp & transmission oil temp).
When it came to fuel gauges I was a little unsure until posts from other members indicated the stock fuel sending unit is 0-90 ohms. So today I decided to test the 4 different fuel gauges that I have. Three of them are regular fuel gauges and one was an LPG gauge.
The Teleflex gauge used in the 86 345 had a 150 ohm 1 or 2 watt resistor tied between the (I)gnition and (S)ending terminals. Using my new fuel tank sending unit I tested the 345 gauge and it was spot on. The LPG gauge also came with the resistor in place so I tested it and it was spot on indicating that it uses a 0-90 ohm sending unit.
I then tested the two fuel gauges that did not have a resistor installed and when the sending unit was on empty the gauge showed half full. When the sending unit was on full the gauge was pegged to the right. I then retested each gauge with the resistor installed and they were both spot on.
Oddly enough the oil pressure gauge from the 345 has the resistor as well so I tested it with the fuel tank sending unit and guess what, it was spot on with 0 ohms being 0 pressure and 90 ohms being 80 psi.
So the point of all this is if you don't have the right sender the gauge isn't going to work
As far as that 90 psi gauge I have no idea what sending unit would work with that gauge. 90 psi is sort of an odd ball number. I've seen Teleflex oil pressure gauges that are 0-100 psi but again I've not seen a sender for them.
Old 12-26-2015, 10:36 AM   #75
Does this make any sense or help?
http://gfretwell.com/electrical/teleflex%20senders.pdf
Old 12-26-2015, 11:36 AM   #76
I ran across that chart awhile back. Most of the senders don't seem to match up well with the gauges Airstream used. One thing of interest, the oil temperature and transmission temperature gauges we have are 160-320 but the closest one Teleflex lists is 140-320. The 140-320F HA157 SS White senders that I bought (I think Peter bought as well) seem to work fine with the 160-320 gauges. So most likely the 140-320 senders from Teleflex will work the the 160-320 gauges.
Notice they don't list a 0-90 psi oil pressure gauge either. Kinda makes you wonder just how many different types of gauges did Teleflex make and what were their applications!
Just the other day one of the gauges I bought had a Blue Bird bus ID tag on it.
It's all so confusing!
Old 12-26-2015, 06:16 PM   #77
Bethany533's Avatar
1983 30' Airstream 300
Covington , Louisiana
Originally Posted by bkahler View Post
Charly,
Hope this helps
Brad,
The speedometer on my '83 is kaput. Do you recommend sending it out for repair or calling Custom Instrument Panels for a replacement? Mine looks most like their XLS54500.
Ray J.
Bethany533 is offline   Reply With Quote
Old 12-26-2015, 06:28 PM   #78
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Want to spend money? Digital outside air temperature gauge, rear axle temperature gauge ,maybe an exhaust temperature gauge......
Old 12-26-2015, 06:44 PM   #79
Ray, are you sure it's not the GM speedometer 53220?
54500 is an electronic speedometer which I would be surprised if yours was like that.
I may have the correct speedometer available. I'll check tomorrow morning.
Old 12-26-2015, 07:15 PM   #80
Bethany533's Avatar
It's cable driven, without tripometer.
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
2003 Airstream Classic 30 Ft. EXCELLENT!!!! S2003 Airstream Classic 30 Ft. EXCELLENT! eBay Watch Airstreams on eBay 0 09-12-2011 09:50 AM
2011 Classic Limited 30 :: 2011 Airstream Classic Limited Wyndridge2 Airstream Registry Discussions 0 08-19-2011 08:32 AM
Classic -vs- Classic Limited 10Smiles Dollars & Cents 11 06-22-2011 08:33 PM
Classic Airstream Motor Home T-shirt and gift items maltnhops Classic Motorhomes 0 03-18-2011 11:10 PM
