My speedometer is totally trash, tachometer occasionally throws a temper tantrum, oil pressure doesn't match the rest, fuel gauge is not calibrated, and the clock is right about once a month.
Rather the try to fix all these things independently, and dance around the original poor wiring, i think I'm just going to bite the bullet and replace all with new matching gauges.
Anyone have any experience with speedhut?
I've been looking at theirs, they are totally customizable, so I can get font/design/bezels that look good in a motorhome (instead of a drag strip mustang), all of which can be gotten with programmible warning lights (good for temps and things you don't actually look at often)
I was thinking about their
GPS speedometer (includes altimeter)
Tachometer
Fuel
Oil pressure
Water temp
Voltage
Manifold Vacuum
A/F ratio
Trans temp
Fuel pressure
Air pressure
Ditching the clock.
So I need to add 2 holes, plenty of space on the 310 dash
Questions
Anyone use speedhut? Open to suggestions.
Are front and rear air pressure the same? Or will I need 2 gauges?
Is oil temp worth getting if I already have trans and water temp?
If you're curious, the configuration I am considering is
Black dial, white font, blue glow
Font: century
Tick: antique
Pointer: white, chrome blade glows white
Bezel: legacy chrome
1983 Airstream 310 Class A Motorhome
-Rob
