Old 01-26-2013, 06:44 PM   #57
A picture can explain it a whole better than I can!
Old 01-27-2013, 07:02 AM   #58
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Looks like they used the shroud as a simple solution to mounting a unit made for a thick board onto a thin plastic, if they would have changed out the aluminum u attaching piece with one with longer legs they wouldn't have needed the glue.
Old 01-27-2013, 08:10 AM   #59
Dave, I don't think that is the case. Here is a picture of the tach without the shroud. The clamp has enough reach to clamp to the thinnest dash.
I have no idea why Airstream did it this way. Actually as strong and sticky as Vulkum is I'm surprised they didn't use it for this application!
Old 01-29-2013, 10:49 AM   #60
I got the new Teleflex speedometer in the mail yesterday. Yes is different than the ones used on the 310s and 345s.
ID:	177701Click image for larger version
However if you take the sun shroud from the old 345 speedometer and install it on the new speedometer it's pretty hard to see any difference. Of course I should have cleaned the dirt off the shroud before I took the picture
ID:	177700Click image for larger version
Not bad for a $25 investment.
Old 09-09-2013, 12:31 PM   #61
kmamedia's Avatar
2002 26' Land Yacht 26
Seabrook , Texas
Might add A Giroscope in case you get into a Turbulance
kmamedia is offline   Reply With Quote
Old 09-09-2013, 04:02 PM   #62
A properly installed "air speed indicator" and a "sensitive altimeter" worked great for me.
They told you when you had a tail wind or head wind, and if you were climbing ever so slightly, so that you could regulate your speed accordingly.
Old 09-11-2013, 02:07 PM   #63
1995 36' Classic 36
Ludington , Michigan
My first trip in the AS was driving it from Seattle home to Colorado. Didn't really notice it in an unfamiliar vehicle but we had a nice steady 30 mph tail wind all the way. A few weeks later we drove it to Michigan with a nice steady tailwind. You can imagine our disappointment when we fought 40 to 50 mph gusty quartering headwinds all 1500 miles home.
I can't wait for the days when my travel days are not dictated by vacation from work.
Kota is offline   Reply With Quote
Old 09-24-2013, 05:27 PM   #64
1995 36' Classic 36
Fuel Pressure Gauge
Got everything ready to go for our fall trip when we got one of "those" family phone calls from Michigan. Ann had to travel back to be with her mother in the hospital. Figured I might as well get some projects completed. Found a place in the dash for the fuel pressure gauge. Its starting to look like the engineers panel in the spruce goose. Some day I'll make a new panel for it. Someday...
Name:	Fuel Pressure Gauge 004 (Large).jpg
ID:	196318   Click image for larger version
Name:	Fuel Pressure Gauge 005 (Large).jpg
Old 12-07-2015, 10:50 PM   #65
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Teleflex
Reviving an old thread here…..
Does anyone have a line on an OEM Air Suspension gauge for my '89 370???
Any thoughts on sources for repair of the existing unit??
Charly
streamquest is offline   Reply With Quote
Old 12-08-2015, 05:53 AM   #66
Charly,
I've been watching for Teleflex gauges on ebay for over two years and have not seen the air suspension gauge show up. However the one company that I know of that still deals in Teleflex gauges seems to list a price for one at $39.69 part number XLS50766-011. That doesn't mean it's available but it would be worth checking on.
Here's the page listing the Teleflex gauges.
And this is Custom Instrument Panels home page.
Hope this helps
Old 12-08-2015, 08:22 AM   #67
I too have not seen one Charly. I am wondering if its a mechanical oil pressure gauge with a different face.
Good link Brad!
Old 12-08-2015, 08:42 AM   #68
Good link Brad!
The air suspension gauge I have is electronic and uses a transmitter similar to those used for the oil pressure gauges.
ID:	253528Click image for larger version
One thing to note. In the link I provided the gauge is listed as 0-150 psi mechanical. Mine is 0-120 psi and uses a transmitter. The part number on my gauge is 53679.
Steve, I thought you might find this page interesting. I don't necessarily like the looks but the process is interesting.
Old 12-08-2015, 08:57 AM   #69
Charly,
This isn't the same style but might work for you in a pinch.
Teleflex 0-150 psi gauge
Old 12-08-2015, 11:58 PM   #70
1936 20' Clipper
1947 22' Liner
Curtis Wright
Thanks!
Brad and Steve, you two are a better source of info than the internet!!
Thanks for the suggestions and sources. My 370 came with an aftermarket gauge attached below the dash to replace the apparently failed original (which was the 0-120 unit that Brad referenced that is evidently discontinued). Since this moho is largely unmolested from original, I'm trying to restore it back to stock wherever possible.
In the case of a 370 on the Gillig chassis, the suspension and parking brake are both dependent on air pressure. Was this "Air Suspension" gauge used on the much more widely produced 345's, 310's, etc.?? I don't recall seeing one on my 325 before rebuilding the dash several years ago. Just thinking about potential "gauge donors".
Thanks again,
Charly
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
2003 Airstream Classic 30 Ft. EXCELLENT!!!! S2003 Airstream Classic 30 Ft. EXCELLENT! eBay Watch Airstreams on eBay 0 09-12-2011 09:50 AM
2011 Classic Limited 30 :: 2011 Airstream Classic Limited Wyndridge2 Airstream Registry Discussions 0 08-19-2011 08:32 AM
Classic -vs- Classic Limited 10Smiles Dollars & Cents 11 06-22-2011 08:33 PM
Classic Airstream Motor Home T-shirt and gift items maltnhops Classic Motorhomes 0 03-18-2011 11:10 PM
