Old 04-23-2013, 04:01 PM   #15
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Wouldn't be the first time a campground was wired wrong. Could have been an open common or ground. If you have 30amp service it's ONLY to be used with 120V and NOT 220/240V. 50amp units are designed for 240V input that's split into two (30 and 20amp) 120V circuits. There are cords that can be used to allow a 50amp plug to be used on a 30amp unit, but it only splits one of the 120V circuits off of the 240V.
92landyacht is offline   Reply With Quote
Old 04-23-2013, 04:41 PM   #16
1988 32' Excella
Robbinsville , New Jersey
Close but, 50amp units are designed for 240V input that's split into two 50amp 120V circuits.
RV Wiring
http://www.myrv.us/electric/Pg/50amp_Service.htm
Old 04-24-2013, 08:43 AM   #17
1992 36' Land Yacht
Grayson , Georgia
True.
Original trailer plug wiring diagram? edglenn Electrical - Systems, Generators, Batteries & Solar 15 05-04-2018 07:55 PM
New 30 amp plug needed ck21084 Batteries, Univolts, Converters & Inverters 21 09-29-2016 11:42 AM
Batteries going dead PhiDor Batteries, Univolts, Converters & Inverters 16 01-26-2012 05:56 PM
What kind of plug terminal is this? bookem666 Electrical - Systems, Generators, Batteries & Solar 3 08-02-2011 08:14 PM
Wet weekend in our Safari OR How I discovered the Blow Out Plug! Brow324 Plumbing - Systems & Fixtures 16 04-18-2011 11:15 AM
