Old 08-16-2004, 09:40 AM   #1
IPM
1996 clipper gas 34'
Blue Springs , Missouri
ac belt routinely pops off 454
anyone else have this problem? My ac belt comes off routinely in my motorhome. I have installed an idler pulley to keep the belt from jumping so much between the compressor and water pump. That works well till the sealed bearing in the idler pulley wears out. Sure need a better solution.
Any solutions out there?
PS
Galax bluegrass festival was great! Parking via the Walley club was well done as well. Weather was overcast but nearly no rain while we were there.
Motorhome pulled the mountains well, temp never got over 180F, of course I don't pull a toad and I'm only 28'.
It's all good
IPM is offline   Reply With Quote
Old 08-16-2004, 09:50 AM   #2
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
My AC has two groves in the pulley. The belt runs around the water pump and around the AC and the Power Steering/Brake pump. Could yours just be misaligned?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 08-16-2004, 10:01 AM   #3
IPM
One grove pulley in mine. Same belt routing as yours. Yep, the water pump pulley may be pressed too far toward the engine. Rather not change the water pump to test that theory....... but I've no problem with the water pump/alternator belt....
ac compressor looks aligned correctly, I've checked that over and over and over......
It's all good
Old 08-16-2004, 10:04 AM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Do you have V belts or Serpentine belts on your MH? If you have serp belts, you might be able to find an automatic tensioner, basically what you have, only instead of a manual adjustment, it is a pre-tensioned spring. Also, if you are wearing out bearings on your idler pulley, you have the belt adjusted too tight. A LITTLE belt jumping between puleys is normal, and tends to be more pronounced the further the pulleys are apart.
I am sure you checked to make sure your pulleys are not bent, you may want to have the alignment of the pulleys checked.
Old 08-16-2004, 10:18 AM   #5
IPM
v belts, the pre-tensioned Serpentine type tensioner is a great idea, pulleys not bent, waterpump pulley alignment suspect but not much, yep probably over tension the belt.
It's all good
Old 08-16-2004, 10:57 AM   #6
LOST , Hawaii
There are short and long water pumps for BB Chevys and different pulleys for each. Short took a flat pulley. Long should have quite a bit of offset back towards the engine. Wrong pulley?
John
74Argosy24MH is offline   Reply With Quote
Old 08-16-2004, 02:13 PM   #7
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
John
When I did the water pump on my 76 all they could get was a short shaft, did not know there was a diff. Belts jumped (100 miles later and would not keep them on) had to shim the water pump pully out about 3/8 of an inch to get to all line up.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-17-2004, 06:57 AM   #8
IPM
That must be the root of my problem. Wrong water pump. Wrong pulley alignment. Wrong pulley?
Not looking forward to replacing the water pump while the radiator is installed. I think I will also check on shimming the pulley out as well first.
thanks ya'll,
MIke
It's all good
Old 05-17-2005, 10:47 AM   #9
Reno , Nevada
I realize this is an older thread, I may need to re-post this elsewhere. But I thought I'd give it a try...
I have a '74 Argosy MH, with a Chevy 454 on a p30. It recently lost a belt and I realized because it got hot (H2O pump quit), and now it would appear that it actually is missing 2 belts. I need to get a belt routing diagram! I have no clue how these should be set up. I've attatched a representation of the pulley layout, the numbers in brackets represent the number of pulley spaces on each shaft. There is currently one small belt that runs directly from the crank to the Power Steering (I think it's the ps) and that is it. I have a hunch that it may be incorrect, I have no idea how it was belted prior to me getting it. It may have been jimmy-rigged. Does anyone have any ideas!? No place here could get me a manual either. AGHHH!!
Thanks in advance for all the help!!
-Logan
pillageTHENburn is offline   Reply With Quote
Old 05-17-2005, 11:20 AM   #10
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I have a 454 in my '84 Suburban, and it has three belts. Although I am not near the truck at the moment, I believe one belt services both the smog pump, and the alternator, another belt spins the water pump & power steering, and the remaining belt runs the A/C & water pump.
If you do not get better replies, PM me and I can pop the hood.
Tom
Old 05-17-2005, 12:19 PM   #11
RivetAddict
swebster's Avatar
Serpentine runs from Crank to Smog to Alternator to Water Pump. V Belt belt runs from Water Pump to A/C to P/S and back to Water Pump. "backup" P/S belt runs from Crank to P/S.
I also used to have a second Smog pump (part of the now removed A.I.R. Emissions system) that sat in between the Alt and the AC. But mine now looks like yours.
Steven Webster
AIR 1760
Old 05-17-2005, 12:21 PM   #12
till's Avatar
Lisle , Illinois
Images: 108
FWIW, how old is the belt, and have you tried fliping it around. I had a new belt that kept poping off. I fliped it end for end and the problem stopped.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
till is offline   Reply With Quote
Old 05-17-2005, 12:34 PM   #13
Hippo's Avatar
Battle Ground , Washington
I had the same problem years ago. I found the AC compressor was not lined up with the other pulleys. Had to shim it and it worked.
Chuck
Hippo is offline   Reply With Quote
Old 05-17-2005, 02:39 PM   #14
Reno , Nevada
Mr. Webster, Thank you!! That is awesome!
The only question I still have is that all pulleys are v-belt pulleys...should I replace any of them with serpentine? I can still do what you've drawn with v-belts right?
Thank you again! Now maybe I can get this thing back home!!
-Logan
Old 05-17-2005, 02:56 PM   #15
LOST , Hawaii
The belt on the LH side of the engine also needs to go around the crank pulley- crank, water pump, ac compessor, power steering. V belts are what you need. My LH belt is about 60" (Dayco 11A1535 15605 and it could be a little shorter that is why I say about 60"), no smog on mine so my length won't help.
John
Old 05-17-2005, 09:08 PM   #16
Reno , Nevada
Thanks John!
Yeah, the more I looked at it the closer I came to that conclusion, this way all three belts hit the drive pulley. Is this what you mean (see picture)?
Old 05-17-2005, 10:04 PM   #17
RivetAddict
swebster's Avatar
That matches my setup
Steven Webster
AIR 1760
Old 05-18-2005, 06:01 AM   #18
LOST , Hawaii
And a third "that's it."
John
Old 05-18-2005, 07:31 AM   #19
RivetAddict
swebster's Avatar
Logan,
I would add that (at least on mine) the passenger side belt is a wide multi groove belt - bascially a serpentine belt. The others are V-Belts
Steven Webster
AIR 1760
Old 05-19-2005, 01:58 PM   #20
Reno , Nevada
Hey everyone! Thanks for all the help and advice!! Here's what ended up happening...
I was finally able to find a Kragen that would tell me where the belts should go (which pulleys each belt should hit). what they told me is noted in the first image... I tried it and quickly found that the belt from the crank to the AC rubbed on two other pulleys.
So I ended up running it like it is in the second picture. I hope there is no problem with running the AC pump strictly off of the H2O pump...
Thanks again for all the help!! Now I need to tackle the hot start problem (or lack there-of). I think I have it worked out, but as always advice is more than welcome!!
-Logan
Whipple supercharger on 454? fangthorpe Mechanics Corner - Engines, Transmission & More... 20 11-03-2010 02:13 AM
Serpentine Belt Question -'92 454 - HELP fangthorpe Mechanics Corner - Engines, Transmission & More... 17 07-25-2010 10:26 AM
454 High Mileage fcycle Mechanics Corner - Engines, Transmission & More... 8 04-21-2004 02:42 PM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Belt replacement on 454 Gas Classic AccessMaster Airstream Motorhome Forums 12 05-03-2003 12:31 AM
