Old 01-25-2007, 04:04 AM   #1
76 Argosy 28' MH
john roeder's Avatar
1975 28' Argosy 28
Springfield , Ohio
A/c
Just wondering how many use there dash A/C. Seems everyone runs thier genset and roof A/C. If that is the case could you remove the A/C from the motor or would that be a mistake. Also on the right side manifold the air tupes were removed and pluged. The left side still has em, not cracked or anything, just wondering if i could just remove the hose to em and put a plug there for now. Then do away with those air pumps. Still learning and having fun . Thanks for everyone's help.
John
Chief 1, You light em = we fight em
john roeder is offline   Reply With Quote
Old 01-25-2007, 12:23 PM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
John
I'm not sure I understand the question, but then I tow a trailer.
Dash A/C = cool while driving.
Roof A/C = cool while stationary. Must be plugged in to power to do this - either shore power or generator.
Respond back with further questions or clarification, or one of you MOHO operators set me straight.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-25-2007, 07:17 PM   #3
noiva's Avatar
Chesapeake , Virginia
Images: 46
Ac
John,
I had a 1989 370LE for a few years, and although my dash AC worked, it was good only on moderately warm days. Simply too much heat with all that glass up front. Most of the folks who have the classics seem to agree that, in general, the dash air doesn't even work. I was a little unusual in that area. However, front dash AC operational or not, you would need the front roof AC (assuming you have two) when the temperature gets hot enough. That's why you read so much about gen sets and roof AC. I used mine when it got too warm, and learned to close off the back half of the coach as well as close the back vents on the roof AC to force as much cool air toward the front as possible. Sometimes I could get away without the additional cool of the dash AC, so I'd run with just the roof air. Most of the time I'd use the dash and roof.
Hope that helps.
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 01-25-2007, 07:28 PM   #4
76 Argosy 28' MH
1975 28' Argosy 28
Springfield , Ohio
Dash A/C
Sorry Dave i guess more information would be better. Have 76 Argosy 28. Just wondering about the dash A/C if it was worth using. Also wondering about the air pumps that goes into the exhaust manifolds. Can you do away or disconnect them. Read were you can, take some work off the motor.
Old 01-25-2007, 07:55 PM   #5
New Borockton , Alabama
Images: 21
I would not remove it whether or not you use it. I know they won't keep up in extreme heat but for moderate days, if it blows cold, why not keep it. Also, relieving the engine from turning the compressor and pulleys on that engine would be hardly noticeable. Correct me but I don't think you will make up any "substantial" gain by removing it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 01-26-2007, 11:27 AM   #6
noiva's Avatar
Images: 46
Ac
I agree with Randy. The effort to remove a functional AC, along with the re-belting problems aren't worth the effort, IMHO. Now, if you're talking about a completely trashed, unrepairable unit, you might get your value out by removing all the stuff, especially the coils in line with the radiator - to give you better air flow. One problem with that, however, is that once it's gone, you'll likely never be able to put Humpty Dumpty back together again, should that become desirable at some future date.
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 01-27-2007, 05:21 AM   #7
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
All the above posts make sence so I'll reply to your AIR needs. Going half way makes little sense to me so .... can't figure out why the po did it. You can remove the tubes and plug but a much better idea is performance headers.
Headman or Doug Thorleys are the most inexpensive fixes here. The manifolds on the 454 are suspect at best. They leak, crack and blow gaskets. The smog/AIR pump drags horsepower from the motor as does the A/C.
If you remove the pump and go to headers you'll be surprised at the amount of room you'll have to work on your motor. That and you'll notice a cooler dog house temp as the headers dissipate heat much better too.
Oh, and you'll have gobbs more power and a bit of economy to boot.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 01-27-2007, 09:31 AM   #8
noiva's Avatar
Images: 46
Just to add to Glen's comments. Be glad you don't have the Ford 460 in a 370LE. I checked on getting headers for mine, and they couldn't fit them in the doghouse space. (At least that what my truck repair shop told me, and they could have made some money by selling me headers.) The best you could hope for on that one was to disconnect and plug, a process way too tight for me to tackle. Apparently there's more room in the 454, P 30 setup. Lots of folks have done headers on them. Glen practically lives in his, so he should know.
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 01-27-2007, 03:34 PM   #9
76 Argosy 28' MH
1975 28' Argosy 28
Springfield , Ohio
remove A/C
Thanks Glen, I got the air pump removed and when the gasket blows again i am going to the headers. Did you remove the A/C pump or are you still using it. It just seems with all the space to cool it is not worth running and with it off there would be a lot of drag taken off the motor and a lot more room to work. Just seems more practial to use the roof top, seems it would cool a lot quicker. New to this and you guys know what your talking about, you been there done that.
Thanks a lot John
Old 01-27-2007, 03:44 PM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Glen is right on track. The ac is notoriously bad in these old Chevys, and I used our roof air and two high mounted front fans exclusively. It only got uncomfortable when the outside temps were 95 plus.
Insulating the doghouse and the front floor area around the driver and passenger went the furthest in cooling our interior. I used two layers of insulation under carpet on this area, and then corked the floor thru the living area
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-28-2007, 07:41 AM   #11
GlenCoombe's Avatar
Belleview , Florida
Images: 27
John, sorry to be so long getting back on the board.... I still have my A/C compressor in place. As it is inop. the clutch is not engaged and there is little drag. I left it in place as I didn't want to mess with the tragectory of the belts on to the hydroboost pump which is on the same belt/pully as the A/C compressor. I'm sure that sooner or later I'll have need to get into it but I am using the old ..."if it ain't broke...." mentallity. I've got enough on my to do list.
Old 01-28-2007, 12:45 PM   #12
76 Argosy 28' MH
1975 28' Argosy 28
Springfield , Ohio
A/c
Thanks Glen,
Going to do the same. Thought that air cleaner was cool so i did the same thing, turned out great, my freinds thought it was the coolest thing they ever saw. Next thing is to replace the brake fluid and bleed the system, just been setting so long thought it would be a good idea. Got my boy checking out the plumping being that's what he does for a living. Other then some small things, i think we'll be ready to go come spring. Again thanks for everyone's help.
Old 01-28-2007, 02:04 PM   #13
steelbird312's Avatar
1956 22' Safari
2013 31' Classic
Crossville , Tennessee
Images: 11
If that is the case could you remove the A/C from the motor or would that be a mistake. John
John, If I'm not mistaken, don't GM A/C's run when you have the defrost function running to clear the windshield, even in cold weather?
Also on the right side manifold the air tupes were removed and pluged. The left side still has em, not cracked or anything, just wondering if i could just remove the hose to em and put a plug there for now. Then do away with those air pumps. John
The air pumps are part of the smog system. I have no idea what your smog tests and inspections are like, but you might need to check locally about that first.
By the way, I have a 390 XL, and after chasing down the entire system through ACME CO, I found that by RE-INSTALLIING the system as Acme meant for it to be, I could cool my unit acceptably through using the dash A/C up to say 85 degrees outside temp, IF I was not facing the sun head on. Above that, or with full head on sun, we run the roof units too.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 02-01-2007, 11:50 AM   #14
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I use my dash air. I keep it charged properly and it cools good. I have thought about making some drapes to go behind the cockpit area making it even more comfortable and would also dampen the noise from the wife's pots and pans on Oklahoma's third world roads.
Mel
choctawmel is offline   Reply With Quote
frig and a/c suggestions Neenm General Appliance Topics 6 04-08-2007 07:42 PM
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
