Old 04-11-2016, 05:46 AM   #1
1982 31' Airstream 310
Greensboro , North Carolina
82' Airstream 310 Motorhome - Need Help
i have an 82' Airstream 310 with a blown Isuzu 6BD1T engine in Memphis Tennessee that i need to either transport to Greensboro NC to have repaired or find a diesel shop near Memphis that can do engine replacement - any suggestions?
Bamaforlife is offline   Reply With Quote
Old 04-11-2016, 06:03 AM   #2
mayco's Avatar
champaign , Illinois
Are you absolutely sure the motor is "blown"?? Typically on these Isuzu 6bd1 motors, they are ruined only by one of two things; running without oil or a severe overheat.
mayco is offline   Reply With Quote
Old 04-11-2016, 06:53 AM   #3
310 engine blown
I have been told it threw a rod and the engine needs a full rebuild[ATTACH]
Name:   Engine Repair 1.jpg
[/ATTACH]
Name:	Engine Repair 3.jpg
Old 04-11-2016, 07:30 AM   #4
Henniker , New Hampshire
If your motor is not salvageable you should check out this eBay posting:
http://www.ebay.com/itm/1983-AIRSTREAM-310-MOTORHOME-DRIVER-SIDEFRONT-WINDSHIELD-WIPER-ARM-L-K-/151936080689?hash=item2360189b31:g:ZkcAAOSwFqJWh0r H&vxp=mtr[/url]
He lists a motor among his 310 parts for sale.
You can see a picture of my 310 (also with a blown motor) being transported on page 4 of this thread:
http://www.airforums.com/forums/f311...-139118-4.html
Good luck!
1982 310 motorhome 502
Henniker New Hampshire
chiefair is online now   Reply With Quote
Old 04-11-2016, 07:50 AM   #5
mayco's Avatar
Ouch!!!!!
Old 04-26-2016, 09:01 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
@Bamaforlife
Sorry for your luck. As I live in Canada I can't help you with your search but I do wish you all the best.
Mayco and I have the same motor and any info would be helpful.
Did the mechanic give you any possible cause? Bad oil, wrong oil?
What kind of mileage did you have on the motor?
It looks like it spun a bearing versus throwing a rod. If it's just a bearing then the block should be fine; or not? Is the block salvageable?
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
310 7.4 sitting 10+ years need help. firejpn Classic Motorhomes 16 01-26-2012 12:12 AM
HELP! Need a bumper for '83 310. Mike Leary General Motorhome Topics 7 07-13-2008 07:23 PM
'84 310 Airstream Motorhome ftbjc Member Introductions 5 10-23-2007 08:24 AM
