Old 05-17-2017, 07:40 PM   #1
1977 28' Argosy 28
Baytown , Texas
8.1L with Allison 1000 4x4 transmisison, anyone convert to drum output brake?
So I'm about to pickup a wrecked chevy 2500 truck for almost free and I plan on swapping in the 8.1l with allison into our 77 28' argosy. That said, is there a kit that can be bought to add a drum brake to the rear where the transfer case goes? I know the zf5 was like that but I'm not sure about the allison. I'm sure I could have something made or make something in the shop but it would be awesome if I could buy a used factory setup and bolt it on.
Jjona5 is offline   Reply With Quote
Old 05-17-2017, 08:19 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I think you need to read this thread and get a hold of modified13 by pm.
It looks like the donor truck he used was 4wd but I do know they came 2wd as well.
Goodluck
Tony
http://www.airforums.com/forums/f311...-a-163471.html
Old 05-18-2017, 06:10 AM   #3
1977 28' Argosy 28
Baytown , Texas
Cool. I sent him a PM to see if he knows. I also posted on a few chevy forums.
Old 05-18-2017, 06:57 AM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I did quite a bit of research when considering this swap last year and I believe the unit used in school buses have a brake on the output shaft. But also swapping from 4x4 to RWD was not straightforward, and I was advised to look for the RWD version (which is pretty rare).
martin300662 is online now   Reply With Quote
Old 05-18-2017, 08:25 PM   #5
1977 28' Argosy 28
Baytown , Texas
Worst case there will be a tcase under there but I'll make a drum brake adapter if need be.
Old 05-19-2017, 10:59 AM   #6
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I'm in the process of swapping a 2008 T-1000 into my Silver Bullet. But I got a housing with the rear flange for the E-brake.
I was looking into the option of a disk brake on the drive shift at the rear end after I found the first T-1000 4X4 tranny cheap. But then I bought a 'package' after I went to SEMA last year. Sold the 4X4 for a good profit.
I'm been away from that project while I heal from back surgery. Just got so finishing up to do on the 1996 Dodge Cummins I put in front of the Allison:<)
choctawmel is offline   Reply With Quote
Newbie debating between f150 Laramie 4x4 and Chevrolet ltz 4x4 cyclistream Towing, Tow Vehicles & Hitches 24 02-05-2017 09:52 AM
Tekonsha P3 giving me 'Brake output shorted' message ronstory Brakes & Brake Controllers 11 05-06-2015 06:30 AM
Hadco Brake Drum rfcjr Brakes & Brake Controllers 3 10-22-2011 08:19 PM
Trailer brake drum sizes? Mike B Brakes & Brake Controllers 3 06-08-2005 09:16 AM
Need Help –Brake Drum HOT! Mookie Brakes & Brake Controllers 12 05-21-2005 09:36 AM
