Old 05-02-2016, 03:21 PM   #1
cdufault's Avatar
1977 28' Argosy 28
Mission Viejo , California
77 P30 parking brake adjistment
How do i adjust the parking brake? The parking brake on my 77 Argosy 28 doesn't hold. I've tightened the cable and handle as much as possible. Am not sure how to adjust the shoes. The manual talks about an access hole, don't see one of those. Do I have to disassemble the parking brake drum on the end of the tranny to adjust the shoes? The rig only has 55k miles, can't imagine the shoes are worn out. The rig doesn't leak, but suppose its possible for shoes to be soaked w trans fluid. Any insight aporeciated.
cdufault is offline   Reply With Quote
Old 05-02-2016, 04:23 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I believe there were a couple different designs on the parking brake cable. On my '82 there are a couple different spots on the linkage near the side of the tranny where you can make adjustment. My drum also doesnt have an access hole to adjust a star wheel. If you could post a picture of the cable linkage near the tranny it might help.
Mike
mayco is online now   Reply With Quote
Old 05-02-2016, 09:22 PM   #3
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Attaching the "brakes" section from my service manual, hope it helps....
Waipio Rim is offline   Reply With Quote
Old 05-22-2016, 10:40 AM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If the drum is the same as p30 1998 you have to look at drum above the drive shaft, mine had the two access points the one at the bottom not used, good light and maybe a mirror will help.
It works the same as a brake shoe on a wheel, star wheel to turn between the shoes to adjust.
P30 split diagonal brake system? mayco Mechanics Corner - Engines, Transmission & More... 9 05-06-2015 11:05 AM
'98 P30 soft Brake Pedal Big Denny Land Yacht/Legacy Motorhomes 3 06-25-2014 07:28 AM
Brake Job on P30? 92landyacht Mechanics Corner - Engines, Transmission & More... 8 04-24-2014 04:43 PM
Courtesy parking or rental parking needed, Perris Valley, California skydiva Our Community 1 01-13-2011 06:13 PM
parking brake on trailor remcolent Brakes & Brake Controllers 1 01-02-2004 09:01 PM
