Old 11-10-2011, 04:59 PM   #1
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
'76 Argosy Steering Stabilizer - help
I have a 76 Argosy MH. I need to replace the steering stabilizer. I bought a cheap one from Autozone. The included bolt that mounts to the steering arm is not long enough to screw the nut on. Nothing is ever easy.
I can't find a Bilstien steering stabilizer for my P30 chassis in 76. I also have the issue that unit needs to include a bolt that will allow me to mount it correctly. The original stabilizer had a bolt that was machine pressed in so I can not re-use it.
Anyone have the model # of a Bilstein that will work? Any other model and part # would be good too.
Can I purchase the bolt that will allow me to mount my existing steering stabilizer. If so, where?
Anyone who has done this: How did you get the bolt on via the chassis?
Thanks for the help. I know it can't be this hard..
MrJ is offline   Reply With Quote
Old 11-10-2011, 07:34 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
My only suggestion would be to take existing bolt to Home Depot, or a good hardware store and see if they don't have something similar in a longer length. Here's what I found online for your model.
Thanks, Derek
Bilstein - KYB - Rancho - Monroe - Edelbrock Automotive Truck Shocks and Struts - Shockwarehouse.com
Old 11-10-2011, 11:27 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I'm not sure what they used in '76 but on my '82 this is what they used.
I got it from Shockwarehouse but they didn't have a listing for it. They said if I could get a Bilstein part number that they could get it. I called Bilstein and they came up with this unit which is the correct one. Their part number is 24-026451. I gave this number to Shockwarehouse and they shipped it as F4-BE3-2645-HO. Their price was $93.58. The mounting bolt for the right end was included.
If this isn't what you need maybe a call to Bilstein will help. They emailed the picture and part number.
Good luck, Dan
Old 11-11-2011, 12:52 AM   #4
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
bolt
The original bolt was pressed into the shock. I cant' take it off...
I saw a Moog steering stabilizer today. I looked like it had a different bolt with an insert.
Old 03-29-2012, 08:20 PM   #5
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Monroe steering stabilzer #555944
I got this stabilizer from Advance Auto approx $80.00. It has an adapter like you seem to be describing. It works great!
Name:	airstream March 2012 033.JPG
ID:	154618   Click image for larger version
Name:	airstream March 2012 034.JPG
Name:	airstream March 2012 035.JPG
Gregsch is offline   Reply With Quote
Old 03-29-2012, 09:46 PM   #6
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
awesome do you have a part #?
Old 03-30-2012, 07:13 PM   #7
Gregsch's Avatar
Tipp City , Ohio
The part # on the box was 555944. The # on the reciept was 555944MM. Even more awesome I paid $68.99. Always check teh Advance website for on-line discounts. You can generally get at least 15% off.
Old 04-01-2012, 11:21 AM   #8
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
I didn't didn't super size your pix so the part# was not visible.
Great pix. I appreciate the help.
How did you get the nuts on the long bolt inside the bumper/frame? I think I'm going to need to cut or drill something to get at it. I got it off with a crow's foot.
Attached is a picture of what my rig looks like. Someone may have modified it, not sure. Does your look the same?
Old 04-02-2012, 07:09 PM   #9
Gregsch's Avatar
Tipp City , Ohio
A can't say for sure if my bumper support looks like that or not. I did not remove the aluminum outer bumper. I have been battling soo many rusty bolts laely that i didn't even try to remove the nuts up under the bumper. I just got out the Sawzall and cut it off. It's really a simple project. Shouldn't more than an hour.
Old 05-08-2012, 09:57 AM   #10
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Got the Monroe 555944. It fits perfectly on my 76! Thanks! The Gabriel from Autozone didn't have the correct bolt. Monroe looks much better.
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
1978 Argosy Steering Gear Leak stereoeric Argosy Motorhomes 3 09-05-2011 11:38 PM
Stabilizer points on 30' Argosy stgerdonly Jacks, Stabilizers, Lifting and Leveling 0 07-21-2011 12:19 PM
'78 Argosy Minuet broken rear stabilizer jack ArgosyMinuet All Argosy Trailers 2 06-20-2011 08:42 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
