Old 07-12-2013, 08:40 PM   #57
Looks like I screwed up the link for the 2nd video. This one should work.
2nd attempt at starting (video) - about 500 meg
Sorry about that!
Old 07-12-2013, 09:30 PM   #58
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Congratulations on getting it going, it sounds great. I'm taking up a collection to get you a fire extinguisher for your birthday.
Waipio Rim is offline   Reply With Quote
Old 07-13-2013, 05:23 AM   #59
Good point, having a fire extinguisher handy isn't a bad idea. I actually have two in the shop, one at each end. I wasn't too concerned about the flames and the first time I actually thought they had gone out. I guess I was trying to focus on to many things at once.
Looks like I was wrong
Old 07-13-2013, 06:17 AM   #60
A fellow Argosy owner uploaded the videos to youtube. Thanks Joseph!
Old 07-13-2013, 10:52 AM   #61
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Hot motor! She sounds sweet!
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 07-13-2013, 07:50 PM   #62
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
very entertaining, lol. Did you just walk away to celebrate and let the wires burn ?
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-15-2013, 08:56 PM   #63
1995 36' Classic 36
Ludington , Michigan
Ya gotta love it when a plan comes together!
Here's a link to project I did a few years ago transporting a computer controlled drivetrain into a classic vehicle.
http://classicbroncos.com/forums/sho...47#post1259047
You should be very comfortable keeping it running on the road with the intimate relationship you've developed!
Kota is offline   Reply With Quote
Old 07-16-2013, 05:09 AM   #64
Naa, had to track down my wire cutters so I cut cut the burning spark plug wires off The darn things just kept burning. Once the one burning wire reached the tie wrap where I had them bundled together the other three started on fire.
I still haven't found anything definitive as to what could have caused it to burst into flame.
Annoying to say the least
Old 07-16-2013, 05:39 AM   #65
OBD II Engine/Transmission Swap - The Next Generation - Page 5 - ClassicBroncos.com Forums
Dakota,
That's an interesting radiator you used on your test stand I don't think I've ever seen anything like that arrangement before.
Between dismantling the 345 and scrapping it out and pretty much rebuilding this Argosy from the ground up, I feel pretty confident that I'll be able to fix anything in it if I need to
Old 07-16-2013, 06:19 AM   #66
1995 36' Classic 36
Dakota,
It's good for about 10 minutes and doesn't get in the way. Easy to flush out an engine to. I use it mostly to check out engines from wrecks for transplant into classics. I look for the most modern version of the engine with electronic controls and transplant the entire system. I look for 98 to 2000 5.0L Ford explorers when I have an application for a 302. You get a dry runner sequential port fuel infected engine with roller cam, serpentine belt system, and all the advancements in economy, emissions, and performance. Usually for a fraction of the cost a bolt on TBI system.
That was my plan for the AS until I found the diesel pusher. However, I am keeping my eyes open for a Ford diesel organ donor! A 2112 F350 Super Duty would be nice.
Old 01-28-2016, 10:43 AM   #67
I'm finally getting back to my motor that's been sitting on the test stand for way to long
Last night I did a test fit of the new Thorley headers and I really like the way they fit. However nothing ever seems to go quite as planned. On my last test run I was using an old set of headers and new spark plug cables. At the time one of the a spark plug cables was either to close or touching the header and caught on fire which quickly put a stop to any testing until I could get new headers and cables.
While searching for replacement spark plug cables they seem to sell two types, over the valve cover (straight) and under the headers (90 degree). The Thorley headers need the over the valve cover style so that's what I bought. Unfortunately I'm still not happy with the routing of the cables. If you look at the pictures below you'll see how close the plug ends come to the headers.
ID:	256432Click image for larger version
ID:	256433Click image for larger version
ID:	256435Click image for larger version
Thorley recommends a minimum of 1" clearance to any cable or plug.
I've installed the GM sheet metal plug guards which helps but the length of the straight plug end is to long and hangs out over the header pipes.
The problem I have is if I order the 90 degree style which would point the wires up and away from the headers the cables will be way to long because they are designed for running under the headers.
My issue just might be in the brand/type of cables I bought that seem to have the extra long spark plug end. I guess I have two choices, find over the valve cover style cables that have shorter ends or buy a universal 90 degree set and cut to fit.
I'm not thrilled about the universal fit idea but will do so if that's the best option.
Any suggestions?!
Old 01-28-2016, 12:46 PM   #68
1982 31' Airstream 310
Henniker , New Hampshire
I installed Banks headers and did not have your clearance issues with my spark plug wires. I did use this GM wire loom kit I got from Amazon: http://www.amazon.com/gp/product/B00...ilpage_o05_s00
I was really impressed with this. Bolts on using valve cover bolts and gives a nice neat installation. Lots cheaper than the fancy billet aftermarket wire loom setups.
Keith
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
Old 01-28-2016, 01:15 PM   #69
Keith
Keith, any chance you can post a picture or two showing your installation?
Thanks!
Old 01-28-2016, 04:08 PM   #70
Left side:
Name:	ImageUploadedByAirstream Forums1454022408.788993.jpg
ID:	256444Click image for larger version
Name:	ImageUploadedByAirstream Forums1454022424.873518.jpg
Right side:
Name:	ImageUploadedByAirstream Forums1454022454.090403.jpg
Name:	ImageUploadedByAirstream Forums1454022473.193749.jpg
1982 310 motorhome 454
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 09:18 PM
Argosy Engine swap beemergb Argosy Motorhomes 3 11-07-2011 08:14 PM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. Onan BIN eBay Watch Airstreams on eBay 0 10-02-2011 10:00 PM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-24-2011 08:20 PM
1977 Argosy Airstream Motorhome Rebuilt Engine, Trans, Headers. CLASSIC , Onan eBay Watch Airstreams on eBay 0 09-13-2011 09:00 PM
