Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 11-21-2005, 08:59 AM   #15
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Arr, arr, arr!
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 11-21-2005, 09:01 AM   #16
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Hey, after you do the conversion, you should get one of these trailers that Tin Hut found:
http://www.airforums.com/forum...ind-19270.html
Why not do the full monte? You'll clearly have all the HP and torque you'll need for the MOHO and the loaded trailer.
Old 11-21-2005, 09:59 AM   #17
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Greg,
Need to look at the longevity of the diesel compared to a gasser too. I have very seldom seen a big block of any brand go much over the 100k mark in an RV, but have seen plenty of 150k+ diesel MoHo, so add the cost of at least one big block rebuild to the equation and the numbers look even better, then start making your own biodiesel and it gets better yet!
Aaron
WBCCI #2449 AIR #2495
Old 11-21-2005, 10:44 AM   #18
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
overlander63 sayeth:
If you think your MoHo is a slug, wait until you get a diesel.
Next forum rally, your going for a ride in my Dmax, with the propane on!
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 11-21-2005, 10:49 AM   #19
Silvertwinkie
Aluminut
Ooooooo. A throw down has been made. I can smell the rubber from here!
Old 11-21-2005, 11:53 AM   #20
swebster
RivetAddict
swebster's Avatar
I won't be happy until I can light up the duallies on my 345! $300 a tire...so what....burn em!
Silvertwinkie...If I could setup one of those trailers with corn thresher on top and a BioDiesel "still" on the bottom I'd be all set.
Steven Webster
AIR 1760
ThisOldRV.com
Old 11-21-2005, 12:05 PM   #21
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Originally Posted by overlander63
Better fuel economy
More torque
Better reliability
No ignition system
Tends to run cooler
Stock 454 HP 230 Stock torque 385 at 1600 RPM.
Stevens done a little tweaking including better headers and exhaust. I bet his motor is making more.
Yeah at 6k Suburban with a 454 gets 10 mpg and a burb with a 6.2 gets 18.
However a 13k motorhome with a 454 gets 9. a 13.5 k motor home with a amped up 6.2 gets 11 maybe 12mpg
So is it worth the change for MAYBE 2-4mpg?
Diesel is more expensive then gas and has been for a while. You will never recover the cost of conversion running it off of straight Diesel.
Seems to be a waste of money to me. Now if your dooing it for fun thats a different story.
If you plan to make BioDiesel...yeah but it will take a LOT of biodeisel to run it and if you are planning on staying out longer then one tank then you eithern eed to carry your chemistry set or be resigned that you are going pay and extra buck a gallon at the pumps on the way back.
For the record I'm looking for a $500 bomb 6.2 Burb right now to play with biodiesel. If it works out realy well that motor may make its way into my pristeen 88 454 burb.
Now stay away from the 6.5. They have weak cranks.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 11-21-2005, 01:44 PM   #22
swebster
RivetAddict
swebster's Avatar
Oh...so its good enough for the burb but not good enough for my MoHo huh? I see how this works. I think you're just trying to keep me out of the "bomb burb" market so you can have them all to yourself.
I have certainly considered the powerplant changover - usally just after I fill up and always after Chaplain Kent or another diesel drive talks about how they are getting 15 mpg. While short term it is motivated by pump prices, long term if I want to keep the MoHo forever...or at least until I can't drive it anymore then maybe this makes sense. I've put almost 40K miles on the 454 in 2.5 years. Now I baby it and take care of it, but still a rebuild every five to six years would be a real bummer.
I'm also wondering when those diesel prices will come down again. Gasoline is 1.97 around here so right now I love my rat motor.
BioDiesel....that is cool. Maybe I could turn a bambi into a giant tank for cooking oil and do an SVO conversion
Steven Webster
AIR 1760
ThisOldRV.com
Old 11-21-2005, 05:14 PM   #23
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Originally Posted by Silvertwinkie
I knew there was a reason I liked you Steve....I mean you and I both have the Tim Allen mentality. Why give it only 25 more horespower when for just a bit more, you can get 200 horses out of it.
While you are at it, why not install a propane injection system in it? You will get alost a third more torque and horsepower...
Change is inevitable, except from a vending machine
AIR#2611
Old 11-21-2005, 06:08 PM   #24
LowellN
LowellN's Avatar
Profile:
You shouldn't have to change the tranny in order to bolt the 6.2 diesel to the tranny in your 345. The only thing you would have to change is the bell housing on the tranny. It's only a few bolts and a swap. Chevy big block to Chevy small block (6.2 diesel is a small block) isn't too hard, Ive seen it done many times. I don't think you have to change the flywheel either, but I may be wrong. Oh, and different motormounts. The stock radiator should be fine also, but if you haven't had it cleaned or recored you may want to do so while you have it out. Sounds like a good idea to me. My grandfather bought a 1985 Silverado new to tow their Sunline when I was a kid, it was a great truck. As far as I know the guy he sold it too in 1990 is still driving it.
"For my part, I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to move."
Robert Louis Stevenson
LowellN is offline   Reply With Quote
Old 11-21-2005, 07:46 PM   #25
slow-canoe
Profile:  London , Ohio
I really like the diesel engines, but a 6.2 would not be to high on my list, short on power and problems with cooling ,needs a bigger radiator than stock. ( but there are some who love them). The 5.9 Cummins would be at the top of the list, a lot of torque plus good fuel mileage . If taken care of should run 500,000 miles in a pickup. But you are talking big bucks.
What I am looking at doing(due to having a doner truck) 6.9 IH diesel out of a 87 Ford pickup rebuilt , use the C-6 transmission after rebuilding it with a TCI towing torque converter and a US Gear overdrive unit to keep RPM's down. I can do all the work myself , freshing up the engine,transmission ,fabricate mounts , brackets and rewire as needed. But if you were going to pay someone to do this it would cost $$$$$ lot.
Hay getting there is most the fun!!
PS: 1975 Argosy 26 foot is the victim, hoping for 14-15MPG?
slow-canoe is offline   Reply With Quote
Old 11-21-2005, 07:59 PM   #26
Coastalview
Coastalview's Avatar
Profile:  1978 29' Ambassador
Carmel , California
slow-canoe , you probably will get 14-15 mpg., with the 6.9
Not super on torgue, but a fuel pincher for its size. An ATS turbo, can give you quite a bit of additional torque, without sacraficing economy. For the C-6 trans, a proven winner, and the US Gear overdrive will keep your conversations at a whisper. Jeff
78 Airstream Ambassador 29'
97 Ford Powerstroke 4x4 Crewcab Shorty
AIR# 649
Coastalview is offline   Reply With Quote
Old 11-21-2005, 08:12 PM   #27
swebster
RivetAddict
swebster's Avatar
I like the idea of a 5.9 too....but they aren't giving those things away. No doubt that the stock 6.2 is a dog, but everything I've read on the diesel page about adding the Banks Sidewinder Turbo Kit says it'll outperform the newer Duramax.
I'm a sucker for a sleeper engine. There is just something kinda cool about the junkyard build up.
BTW - This is a fun post. It's drawing out all of those closet diesel people!
Steven Webster
AIR 1760
ThisOldRV.com
Old 11-21-2005, 08:33 PM   #28
Coastalview
Carmel , California
Thats very funny!
In our area, there seems to be quite a few of those 5.9 cummins diesel Dodges for sale, and cheap to boot! I still like this engine, but never liked the truck. Its amazing, just how much you can turn up the ponies, on a Duramax,Powerstroke, and Cummins. Our Ford is tweaked a bit, makes our 28', seem like a tent trailer in tow. If I keep my foot out of it, pulling averages 15 mpg@ 60mph., with a combined weight of 14,300 lbs. As for climibing grades, gee officer, I thought everone else was just pulling to the right to be courteous
AIR# 649
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 10:28 PM
repower 310 Turbo joepospisil Mechanics Corner - Engines, Transmission & More... 10 11-07-2003 07:33 AM
1981 Airstream Excella Diesel dienst1 Airstream Motorhome Forums 6 10-02-2003 04:45 PM
Isuzu Turbo Diesel stuart1 Mechanics Corner - Engines, Transmission & More... 0 10-28-2002 01:23 PM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
