Old 11-02-2015, 03:24 PM   #99
On the Argosies and the early Classics with the vertical radiator I believe if you remove that front cross member you can drop the radiator out from below. The cross member is directly below the radiator and my first guess is it was placed in that location to protect the radiator.
Old 11-02-2015, 06:09 PM   #100
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Originally Posted by J. Morgan View Post
If I were doing that swap....
I would think about cutting that front crossmember at a point fairly close to the frame rail on each side, (but not too close) to make the cross member bolt in and bolt out.
By doing this and removing the bumper, the many ins and outs you are going to have to do will be much easier, and also, future possible repair issues will be easier. (In and out with the head on would be cool).
Of course I really don't know if that will work on that vehicle, but I would be thinking about making that move if at all possible.
Brevi tempore!
My plan was to cut out the front frame out, but after getting the 454 out, the cummins had no problem clearing that. The engine cradle area, that's the challenge.
choctawmel is offline   Reply With Quote
Old 11-02-2015, 06:23 PM   #101
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
I took all the brackets off and tried again, but couldn't get the engine back to the motor mounts. Tranny's got to move back. Should have kept the transmission jack I borrowed when I JUST fix the hydraulic lift pump. And now someone else has borrowed it.
The waiting games regins.
Should have bought that one I saw on craigslist a couple years back.
Well I need to get on the internet and be lied to again anyway.
Got another mission trip coming up, so delay is welcome... right now. Four weeks and I want this on the road!
Old 11-03-2015, 07:53 AM   #102
1995 36' Classic 36
Ludington , Michigan
Originally Posted by Punch View Post
...... and a vacuum pump, if you have the vacuum operated HVAC controls, which I think you would.
If the only vacuum requirement is HVAC, they make a nice little electric pump with reservoir.
You can put an air compressor on it...
Kota is offline   Reply With Quote
Old 11-03-2015, 06:27 PM   #103
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
[QUOTE=Keyair;1705236]Mel,
For your reference, here is some pictures I got from Dave(WXBouy), of his Original 6BT installed in his 345. Hope this is OK to post Dave...
QUOTE]
Steve, Absolutely!
Mel,
Since I have the only one (that I know of) with an original cumin's 5.9 6BTA up front, I am more than happy to take what ever pictures or measurements you may want. The biggest issue I had was replacing the motor mounts since they were unknown to anyone that deals with the P-30/32 chassis. In the end we just ended up pressing new bushings in the old mounts.
Let me know what you need!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 11-03-2015, 07:10 PM   #104
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
[QUOTE=wxbuoy;1705786]
Mel,
QUOTE]
Steve, Absolutely!
Mel,
Thanks. As I work on getting the motor in, I know that the original air inlet is toast. It's got to turn forward because I'm planning to mount the intercooler on the top of the radiator frame. I saw a Case fork lift w/commins (4 cylinder) and ordered that inlet, but it's a 2 1/2" so I'm back to squire one on that.
You know want the p/n is on the engine air inlet of yours?
Waiting for transmission jack before continuing.
Old 11-03-2015, 07:14 PM   #105
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
This baby has the vacuum pump behind he P/S pump. Wish it have the air pump that goes between the P/S pump and the vacuum pump, could get rid of the air pump in the back of the bedroom for the air ride.
Old 11-03-2015, 09:18 PM   #106
1995 36' Classic 36
That's what I was thinking. The common configuration is the air compressor with the hydraulic pump piggybacked on it. Loose the engine driven vacuum pump. It's sized for a brake booster.
Old 11-04-2015, 08:56 AM   #107
Cool Dave!
I think there is no better reference that your MH.
What Mel is doing is exactly what I hope to do... 6bt with a 4l80e. I think any info you have on your install would be helpful.
Old 11-04-2015, 12:51 PM   #108
Mel,
QUOTE]
Steve, Absolutely!
Mel,
Dave, did your's come from Airstream with the Cummins installed?
Old 11-04-2015, 01:42 PM   #109
[QUOTE=bkahler;1706131]
Yup, Dave owns something rare and special...
Old 11-05-2015, 07:14 AM   #110
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Got the transmission jack, dropped the drive shaft, moved the tranny back and got the block setting on the motor mounts, but can't get the bolt in. Looks like I will need to unbolt the bottom from the frame, get the mount bolts in then rebolt to the frame. It would be easier to do 15 years ago
No room to the A/C pump.
Got to get a different mount for the A/C.
Figure out some way to work the engine stop lever, no room for original.
The front cross member, the one laying in the frame under he motor, is scrap now.
Just been sitting here staring at it for the last couple days as I hunt for information on the 'puter
Old 11-05-2015, 08:38 AM   #111
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Just keep it going Mel.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 11-05-2015, 06:10 PM   #112
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Over did myself yesterday. Went parts shopping today. Cummins is dang proud of there parts!
Need to remember to make a list of all these p/n needed.
I got less then 4 weeks to get-r-done!
Late 454 vs early 454 & 400 vs 4L80E gbell Mechanics Corner - Engines, Transmission & More... 33 07-01-2017 05:59 AM
To Cummins or Not to Cummins?? Help!! On the brink! big_john Tow Vehicles 33 03-23-2010 08:20 PM
First impressions of my new Dodge/Cummins tow vehicle idahosafari Tow Vehicles 14 04-17-2004 08:31 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 02:34 PM
