Old 07-16-2017, 02:38 PM   #421
Congratulations Mel!
Nice install on the generator tank. Do you have any way of telling the fuel level in the little tank?
Old 07-17-2017, 05:59 AM   #422
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
454 to Cummins
Mel,
If you're seeing 1200 @ 27 WOT and if the EGT probe is before turbo right out of the manifold, I'd agree pour yourself a tall one and plan a shakedown.
How's the acceleration? It ain't a race rig I know but Cummins has a geterdone style of power.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-18-2017, 08:36 AM   #423
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Originally Posted by GCinSC2 View Post
Mel,
Gary
It snaps right good till it hits 4th gear (1/1) then she knows it's pulling 16,750 pounds. Acceleration is not at all like the 454. At cruising speed I think it's less noise then the gas was.
The EGT probe is in the exhaust manifold down stream of 4-5-6. I had an 'RV' manifold where the turbo sets down against the block.
Shot a can of die in the a/c, but couldn't see where if came out. Got a leak somewhere cause I can't pull a vacuum. Need to find someone with good color vision.
choctawmel is offline   Reply With Quote
Old 07-18-2017, 09:15 AM   #424
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Big thumbs up Mel!! You sure stayed with it, so cool to hear its on the road (a few miles on her anyway). And to think, back surgery right in the middle of the project, you're a stubborn rascal! You weren't gonna let it beat ya....GREAT WORK!
Mike
mayco is offline   Reply With Quote
Old 07-18-2017, 10:48 AM   #425
GCinSC2's Avatar
Mel,
Confused, accelerates better than 454 or not as good as?
Gary
S/OS #001
Old 07-18-2017, 02:57 PM   #426
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
The original fill was in the top. I moved it to the rear top. There is a bezel for a sender but I didn't put one in. Should have.
So a yard stick will do the trick.
Old 07-18-2017, 03:22 PM   #427
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Mel,
Gary
Not as good.
I'll say it is close till it hit 4th gear. I have no problem merging onto the interstate. I think it hold highway speed better then the gas'r did. But then I have a 6 speed transmission and was 4 speed.
Need to figure out how to up the shift rpm a little.
Still tweaking the fuel wheel. Need to get EGT up another 50 degrees.
Old 07-19-2017, 05:18 AM   #428
What about something like this?
Old 07-19-2017, 05:24 PM   #429
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
One of them came with it, but now the fill is 4" long and out the side, so the gauge don't see any fuel. maybe they make one about 2'-6" longer?
Now the generator governor is not governing.... RATS!
Put new blinds in the kitchen/living and bathroom today.
Think I need help with the dash air Can't figure it out.
Old 07-19-2017, 05:41 PM   #430
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Thumbs up Great!
Not as good.
Where I used to work, our never exceed EGT was 1300 degrees. I would stop at 1250 for a little extra insurance.
Of course, that was on tractors. Pulling a plow, that was a long-term temp.
1250 would have been the number I recommended to you, too, so we agree.
The pistons shouldn't start to melt till well over 1300 sustained.
Vaughan
Old 07-19-2017, 05:55 PM   #431
My diesel powered steam cleaner has one that is about 12" or so long. I'll see if I can find where it came from.
Old 09-15-2017, 10:59 AM   #432
GCinSC2's Avatar
Mel,
Been a few months now, how's the Cummins doing?
Gary
S/OS #001
Old 09-16-2017, 02:05 PM   #433
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Mel,
Gary
So far I've only gone about 240 miles pulling the toad (1999 Suzuki Vitara). Haven't refilled yet.
Dropped the generator tank and put the gauge in it.
Pulled the 3" turban down pipe and replace with a 4".... Still wanting the EGT lower. Think I cut and welded the Summit down pipe about 12 time to clear everything. Then I wrapped it and liked to never got the thing bolted back onto the turban.
Now I'm working on installing a new 3 view backup camera system.
It is my life project! I'll never be done.
Old 10-18-2017, 05:08 PM   #434
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Time for the truthful update.
Have gone 450 miles pulling the toad and I filled up today.
Got 9.6 mpg. Was hoping for a minimum of 10 mpg, but this is the first tank fill.
Still think I've got a inlet leak as the EGT is still going up to 1300 degrees.
I hope to talk to the real diesel mechanic this weekend as I plan to go on another (bicycle) trip with it.
I did replace the 3" turban down pipe with 4" which did help the EGT.
After this weekend my plan is to remove the caption's chairs and have redone then replace the carpet under them and add insulation/sound proofing. Anyone know if someone has pre-made carpet? I'm sure when I pull this carpet up I'll render it unusable.
I think I like what I did.
Late 454 vs early 454 & 400 vs 4L80E gbell Mechanics Corner - Engines, Transmission & More... 33 07-01-2017 05:59 AM
To Cummins or Not to Cummins?? Help!! On the brink! big_john Tow Vehicles 33 03-23-2010 08:20 PM
First impressions of my new Dodge/Cummins tow vehicle idahosafari Tow Vehicles 14 04-17-2004 08:31 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 02:34 PM
