Old 03-21-2016, 10:59 AM   #225
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Got my gauges all installed and fired 'r' up.
'Peddle to the metal' the tach reads 2400 rpms. Maybe the tach isn't reading right ????? I thought it would max out close to 2700 rpm?????
So, at 2400 rpm, no load from top to bottom:
Boost: 7 psi
EGT: 4000 degrees
IP input: 10-12 psi (lift pump psi should be higher)
Lift pump input ????
The cheap 'Glow Gauge' pressure gauge bounces from 0-30 from the tank to the lift pump. I put a 5 psi regulator.
Think I'll go buy me another (but good) oil pressure gauge and throw the cheap 'Glow Gauge' in the trash. I've bought 3 'Glow Gauge' gauges. This one will join the other two a the land fill.
It's the wrong color anyway.
choctawmel is offline   Reply With Quote
Old 03-21-2016, 11:06 AM   #226
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Mel
If the EGT'S are reading 4000 you are going to do damage. The egt should no be over 1100 on a hard pull
shepherd57 is offline   Reply With Quote
Old 03-21-2016, 11:15 AM   #227
Originally Posted by shepherd57 View Post
Mel
I was just going to suggest that maybe he read the gauge wrong! I can't believe the exhaust could get that hot.
Old 03-21-2016, 11:47 AM   #228
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Shouldnt one be concerned of any reading over 1300
mayco is offline   Reply With Quote
Old 03-21-2016, 12:04 PM   #229
Old 03-21-2016, 12:10 PM   #230
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
And that's w/o a load.
I don't know why the lift pump is only producing 12 psi @2400 rpm.... Should be 12 at idle and 30 psi at speed. This maybe why it would act like it was starving for fuel when I did take it out on the road and why the EGT is 4000 degrees. May be running lean even w/o a load. Would take it for a run today, but the wind's blowing at 30+ mph and for the rest of the week.
I haven't dropped the tank and removed the high pressure fuel pump yet. Was hopping to get by with the Holley 5 pound regulator inline till I ran the fuel out.
Here's the problems: fuel pressure too high to lift pump; lift pump too low, not getting max rpm and need exhaust system.
Wonder it I could put the right pressure electric pump in the tank and bypass the mechanical lift pump????
Got to quite running off so much. Was gone 2 1/2 months this winter. I'm packing now to go an a mission trip and won't be back till 10 April..... Then I'm gone again almost all of May into June.
Can't find anything now. I need a job so I can rest!
Old 03-21-2016, 12:20 PM   #231
shepherd57's Avatar
Lindsay , Ontario
Mike
If you are getting 1300 I would be finding out why. 1100 max on a long pull mine runs 950 to 1000 and I worry it is to hot.
Heading out now to see if I can find a couple of fan belts
Old 03-21-2016, 12:29 PM   #232
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Need to correct the trash gauge... It's a 'Glow Shift' gauge! None are worth bring home.
Old 03-21-2016, 12:36 PM   #233
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Mel as others stated 4000 deg is just wrong.
Do you have an IR temp gun? Hit the same area as thermocouple for a check. Expect it to be lower. On the outside.
Boost. I don't think you're going to see peak boost w/o putting the Cummins in harness and asking it to do real work not just revving it up.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-21-2016, 01:40 PM   #234
mayco's Avatar
Yes John, Ive never seen my EGT go over 1200 on a long pull. I just thought I had read to keep it under 1300 on the Isuzu or you risk damage to the motor.
Old 03-21-2016, 01:49 PM   #235
mayco's Avatar
May be different on the Cummins.
Old 03-21-2016, 06:20 PM   #236
GCinSC2's Avatar
454 to Cummins
Aluminum has its heat limits.
S/OS #001
Old 03-21-2016, 07:37 PM   #237
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Well maybe it's in hundred and not thousands? The 2400 rpm at full throttle is not right either.... or the pulley ratio is way off
Next chance I get I'll swap the fuel pressure gauges and see what they read then.
Old 03-21-2016, 08:10 PM   #238
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The old line of thought was 1250 degrees was max safe temp before things started to melt. I have been told some of the new technology allows higher temps. The thermocouple probe is mounted in the exhaust manifold before the turbo. Mounting after the turbo will give you a cooler temp.
On my 280 the original BAE pyrometer would approach 1200-1250 if pushed on a grade. It's readings were fairly consistent and predictable. Finally the gauge gave up the ghost. I replaced it with an Isspro gauge. Isspro is considered to be a quality gauge. The readings were frightening. It would show 1300 degrees under a moderate acceleration.
I called Isspro and they sent me another gauge. It showed the same kind of temps. In frustration I bought an Auto Meter pyrometer. Surprisingly it showed the same temps as the Isspro gauges.
Now was the BAE gauge correct and the three replacement gauges wrong or the other way around. Bottom line who can say for sure. What I do is watch both the boost, exhaust temp and exhaust smoke and drive on the conservative side. There is no need to drive pedal to the metal as it is a recreational vehicle and I am certainly not on the clock. I see no reason to be at more then 75-80% throttle. It makes me happy and the old Isuzu seems happy as it continues to rumble down the highway.
Cheers, Dan
~ Margaret Thatcher ~
Late 454 vs early 454 & 400 vs 4L80E gbell Mechanics Corner - Engines, Transmission & More... 33 07-01-2017 05:59 AM
To Cummins or Not to Cummins?? Help!! On the brink! big_john Tow Vehicles 33 03-23-2010 08:20 PM
First impressions of my new Dodge/Cummins tow vehicle idahosafari Tow Vehicles 14 04-17-2004 08:31 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 02:34 PM
