Old 01-01-2016, 12:21 PM   #197
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by tjdonahoe View Post
I believe if you check it out you'll find from the factory the automatic engines have more hp than with the Manuel trans .
Mel has my old manual, but this is a link to specs for 96-98 engines, manual beats auto. 96-98 engine specs
Now if you get into the last few years of Ram Cummins, the auto has beat the manual. The G56 manual was introduced in late '05.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 01-03-2016, 09:06 AM   #198
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Actually the 1996 cummins stock is:
automatic: 180hp; 420 torque
Manual: 215hp; 440 torque
choctawmel is offline   Reply With Quote
Old 01-03-2016, 09:15 AM   #199
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Originally Posted by GCinSC2 View Post
Mel,
I sorta think I understand the current status, maybe.
Any chance you can temp rig a gravity feed fuel setup just to test the assumed standard pump and engine?
A bit over simplified but you've done more challenging stuff all ready.
Happy new year Mel.
Gary
I have the 70psi off the in-tank pump regulated down to 5psi now and, when I return from the AZ sun, I hope I will have the right banjo bolt waiting so/as to read the pressure off the lift pump which should tell me whether the IP is the problem.
Hope I can drive the fuel out of the tank before I drop it out and replace the in-tank pump with something w/around 5psi o/p.
mel
Old 01-04-2016, 07:16 AM   #200
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Chart I seen showed 07 6.7 350 hp. Auto-650 torque.
Man-610. ".
The new technology is amazing..
Old 01-04-2016, 07:56 AM   #201
GCinSC2's Avatar
Look up specs for current model year numbers, the torque wars continue.
S/OS #001
Old 02-25-2016, 12:15 PM   #202
SpiceStream's Avatar
1984 31' Airstream310
Sullivan , Wisconsin
6BT Swap Running
Not sure if this is a conversion anyone is considering doing or in the middle of, but I would say it is definitely worth it. I bought a 1984 310 with a 6bt/Allison 545 conversion and Gear Vendors Overdrive and it rolls down the freeway like a dream. I bought it 2000 miles from home, towed a car home with it no problem, averaged 14MPG as well doing the speed limit all the way. Let me know if you need any info on the swap, I did not do the swap but I have the Motorhome and the guy that did the swap has become a good friend so I can help in one way or another.
SpiceStream is offline   Reply With Quote
Old 02-25-2016, 12:23 PM   #203
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
How is the Gear Vendor connected to the Allison 545. I have the same setup but no overdrive.
shepherd57 is offline   Reply With Quote
Old 02-25-2016, 02:41 PM   #204
It is mounted midship, I will find out if the drive shaft was cut and re-worked or if there is a drive shaft combination that works. My guess is the former. I will say, it gets you gear you need for modern highway speeds. The cost to add it was not trivial, but I can say it is nice. The Tach is not functional in the coach, but when I get that working, I will post the RPM and speed Specs.
Old 02-25-2016, 02:47 PM   #205
I can get you a copy of the GV manual if it is not available online if that helps.
Old 02-25-2016, 03:49 PM   #206
shepherd57's Avatar
Lindsay , Ontario
That would be great if you could do that. I have the Isuzu diesel with the 545 and it needs another gear on the highway to bring the revs down.
Is the gear vendors mounted midships where the hanger bearing was.
Old 02-25-2016, 09:13 PM   #207
just ahead of the hanger bearing.
i will try to get a better picture tomorrow morning.
Old 02-26-2016, 09:13 AM   #208
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
My conversion is still in progress. I've just taken the winter off and got out of town.
Thanks for the offer of helpful information.
Old 02-26-2016, 09:29 AM   #209
I am happy to hear that you are just taking the winter off, it would be a shame to not finish your project, you will love the end result, let me know if you hit any more snags, it looks like you are close.
Old 02-26-2016, 11:16 AM   #210
shepherd57's Avatar
Lindsay , Ontario
Do you know the model of the gear vendors any I have seen mount to the trans in place of the trans tail shaft. How long is the drive shaft ahead of the gear vendor.
Late 454 vs early 454 & 400 vs 4L80E gbell Mechanics Corner - Engines, Transmission & More... 33 07-01-2017 06:59 AM
To Cummins or Not to Cummins?? Help!! On the brink! big_john Tow Vehicles 33 03-23-2010 09:20 PM
First impressions of my new Dodge/Cummins tow vehicle idahosafari Tow Vehicles 14 04-17-2004 09:31 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 03:34 PM
