Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 10-07-2003, 02:14 PM   #1
Tom & Janet Salhus
Tom & Janet Salhus's Avatar
Profile:
454 chevy timing
Hello, We are new to the forum and new to the Airstream Motor Home. We have had the 90- 345 LE for about three weeks now. I am in the process of tuning it up now and am trying to check the timing on it but that does not apear to be as easy as it is on my 51 Mecury with a flathead in it. We have the 454 chevy with the banks power pack. I cant get to the timing mark from the top, is there a beter way to approach timing of this motor
Tom & Janet Salhus is offline   Reply With Quote
Old 10-07-2003, 02:24 PM   #2
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Check if you have secondary timing marks installed. Mine are bolted to the oil pan and easily accessible from the bottom. Instead of using cyl #1 for setting the timing, you will have to use #5 or #8 (to make up for the 90 degrees offset to the factory timing marks.)
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 10-07-2003, 02:48 PM   #3
Tom & Janet Salhus
Profile:
Thanks Peter H, I just went out and looked and shure enogh there are timing marks right where you said they should be. Thanks very much. We are planing our first trip with it for the end of November. We are brand new to this Motor Home thing and we are looking forward to our first trip but I want it to be a successful fun trip for my wife especialy. I am a retired owner operator, coast to coast, over the road driver so it is going to be great for us with this Airstream. Thanks Again, Tom
Old 10-07-2003, 03:14 PM   #4
PeterH-79MH
Profile:
Images: 63
Tom, no problem, glad I could help.
That sure is a nice rig, the 1990 345LE. I am sure you will enjoy driving it a lot after being a big rig operator.
If you happen to find your timing being advanced to factory specs, think twice about changing it. There are some weird gearheads out there (I am one) who believe that the BB chevys run better advanced, especially in extreme mountain driving.
BTW, welcome to the forum!
Old 10-07-2003, 03:29 PM   #5
Tom & Janet Salhus
Profile:
PeterH, Have you had any experienenc, pros or cons of instaling a spliter gear box, US Gear or Gear vender? I have been thinking of instaling on or the other but not shure about it. On pulling grades I would think it would be very good but I don't know if the motor, 454, is designed for the higher RPMs on a pull. Any comment is great
Old 10-07-2003, 03:40 PM   #6
PeterH-79MH
Profile:
Images: 63
Tom, there are some MH owners on the forum who installed a gear vendor.
No personal experience other than the desire for one and a recommendation from my local transmission guy.
My primary reason for installing one would be the OD function for hwy travel. Never had to use 1st gear when climbing 10k + passes.
Old 10-07-2003, 03:48 PM   #7
Tom & Janet Salhus
Profile:
Thanks for the comeback PeterH, I will do some checking out on the form. It makes sence to me to split the long gap betwen 2&3 but I think I had better take a few trips and get the feel of the unit. Tom
Old 10-08-2003, 06:31 AM   #8
74Argosy24MH
Profile:  LOST , Hawaii
I put in a U. S. Gear overdrive. I asked several places about one being significantly better and didn't really get a definitive answer, so I bought the cheapest one I could off ebay. It came out of a mh that had burned so I had to get the control unit also, but installation was easy, the od replaced the tail shaft housing, run 4 wires, mount the control box and switch. The hardest part was finding a decent price to get the drive shaft shortened.
I got the od because of the decrease in engine rpm and mileage. My mh is quite a bit lighter than yours so I am not as concerned about hills. The underdrive ratio is 1.25 so it will significantly increase rpm, but it will be for a relatively short time and shouldn't affect the engine unless it is already weak.
John
74Argosy24MH is offline   Reply With Quote
Suburban or Van with a 350 or 454...which do you prefer? texasphilter On The Road... 12 04-06-2004 03:05 PM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Chevy 454 backfire at speed leomarcotte Mechanics Corner - Engines, Transmission & More... 25 09-14-2003 07:40 PM
'81 454 prevenative maint. & upgrades IPM Mechanics Corner - Engines, Transmission & More... 10 09-02-2003 10:29 AM
Chevy 454 PCV valve question 1985air345 Mechanics Corner - Engines, Transmission & More... 4 03-01-2003 09:48 PM
Forums Directory
