Old 06-02-2009, 12:44 PM   #1
Chuckles's Avatar
Iwerne Minster , Dorset. UK
Cool 4 speed verses GV
I have the standard 3 speed Auto on a '82 build 1983 310. I have tried looking at the GV overdrive but by the time it gets here in the UK it's "Megga Bucks!".
I may have the opportunity to obtain a 4 speed unit, in which I believe the fourth gear is virtually the same ratio as the overdrive unit, is this correct?
My question is, can the 4 speed be a direct exchange fitted (Give or take a cable or two) and am I on the right track? Or should I "bite the bullet" and go for the GV?
Thanks in advance
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 06-03-2009, 04:12 AM   #2
Chuck,
Which 4-speed transmission are you looking at? The only two that I'm aware of that would work are the 4L80E and the 700R4 (4L60?). The 4L80E would be the better of the two choices. I have a 4L80E that I will eventually install in our 1984 310, I just haven't had the time to tackle that project as yet.
You will likely have to shorten your driveshaft a little and if you're going to use the 4L80E you're going to need the computer that goes with it and some additional sensors added to your engine to control it, although there are some aftermarket control boxes that replace the original factory control box.
Old 06-03-2009, 11:28 AM   #3
1972 Travelux Princess 25
Cobourg , Ontario
The newer 4 speed automatics are computer controlled. Whether they can be integrated into your vehicle systems I don't know, but I would be asking about this before I started changing transmissions.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 06-03-2009, 12:25 PM   #4
Chuckles's Avatar
Hey you two, that was something I never gave a thought to! Computers eh!
Yuk! I hate them with a passion, but having said that what am I driving at present? a Merc and a Chrysler PT - both with ECU's.....
OK so I had better do some more swatting up. I have a mate that has a 250 with a 4L80E - I think, anyway I will have a nose round that and see what's involved.
Thank you guys for your input it has certainly made me sit up and think - Still doesn't the GV have some sort of controller/ECU? - It's all good fun!!!
Chuck
Dorset UK
Old 06-03-2009, 01:43 PM   #5
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
I have the GV in my truck behind a C6. The GV does have a control unit that allows for automatic engagement between gears, a floor switch that facilitates on and off once your speed is reached for a manual approach and a switch on the dash that lets you be in charge when you want to switch between manual operation and auto operation. And ofcourse the wiring harnesses to make all that stuff work. But if you wanted to be completely computer free then you would just toggle the solenoid on and off everytime you hit 30 mph. I myself would forget to turn it off and end up leaving the light with overdrive still engaged but thats just me... but it could be done.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 06-03-2009, 02:08 PM   #6
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
A lot of mo/hos had the rear-end gear ratios changed to get some highway speed, especially on the diesels, but they pulled like a slug on hills, even in low. Whatever you do with transmissions and/or OD units, the driveshaft will have to be shortened, and by someone who knows his stuff; the angle is critical: you could take out the u-joints, the middle carrier bearing and the rear end if the alignment is not spot on. I get 65 (US) mph at 3200 with my U.S. Gear o.d. Yes, a ECU comes with the o.d., at least, mine. I'm on my second module, but, geez, look at my mileage! U.S. Gear Corporation Home Page
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 06-03-2009, 02:48 PM   #7
moderator
Airslide's Avatar
Wilton , California
Images: 50
Hello Mike,
The angles are important. Good comment. I actually had to address that on my truck.
I am surprised that your up to 3200 rpm at 65mph. You must have 4.10's or lower?
I have 3.55's and with a highway speed of 65mph I am at 2300 rpm. Now granted while im climbing a hill i might be in second gear with the GV applied. I have to split the gears to find that sweet spot but im getting 14mpg towing with a pretty heavy setup. I think i was in the 10mpg before.
Vinnie
Old 06-03-2009, 06:02 PM   #8
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I also had the US Gear overdrive in my truck. I think it would be the better way for Chuck to get an extra gear without needing a computer. That said, I think the Gearvendors unit is really the same as the overdrive unit in older Volvo cars. It may be easier to get parts from that direction.
Old 06-03-2009, 08:50 PM   #9
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
I just got a 4l80e in my 75 argosy working last weekend. So far I like it, shifts so nice and smooth. Too soon to tell about mileage, 2100 rpm/55 mph. Drive shaft work was only $160. You will need to change the speedometer ,as there is no mechanical output for the old speedo cable The good part of that, is you can get a KPH speedo
bibbs
bibbs is offline   Reply With Quote
Old 06-04-2009, 11:14 AM   #10
bibbs
Bibbs,
What engine are you running in your 75 Argosy, 454 or 350?
Also, if you are running a carburetor what did you do for a computer/ecu? I'd like to install the 4L80E that I have in our 454 powered Argosy but haven't taken the time to figure out the best way to control it yet.
Thanks!
Old 06-04-2009, 02:13 PM   #11
Mike Leary's Avatar
Images: 11
Isuzu likes it at 3200; bear in mind, it was designed to be a stationary engine; running fishing boat gen sets, etc. I burn no oil, get 15 mpg. I got tons of paperwork when we bought the coach. no indication that the rear end had been modified, though it's common.
Old 06-04-2009, 11:27 PM   #12
Chuckles's Avatar
Thanks Guys for all this information, Forums to the rescue yet again!
I may have miss-led you all a bit on the computer front. I do hate them but resigned to having them! In other words if needs must..... as they say.
As a mechanical engineer I see so many applications and controls that have been taken over by "boffins" and their PC's and make a total hash of things, whereas my mechanical designs go on 'ad~infinitum'. So as an old codger, I have these reservations.
I must say that it hurts a bit when you see that the Laycock Overdrive - now Gear Vendors - started in the UK and now is in the USA, and consequently adds the shipping costs to it all. Funny thing is that no one in the UK knows - or wants to know - anything about an overdrive for a large vehicle.
The information and banter here has certainly helped although no decision is made yet.
I just need to get more 'gas-miles' with the cost of fuel here still exorbitant. Its a choice of propane conversion or overdrive - OR BOTH!
Thanks again
Chuck
Dorset UK
Old 06-05-2009, 07:30 PM   #13
bibbs's Avatar
1975 26' Argosy 26
Vista , California
I have a 454,and a TBI conversion I bought an after market wiring harness and computer. But you cam buy a PCM and wiring harness for carb setups for $500 or $600.
Bibbs
Old 06-07-2009, 12:13 PM   #14
Cobourg , Ontario
Chuckles have you worked out how many miles you drive per year, how much fuel you burn, and how much you could realistically save with a new transmission?
In many cases it will take 10 years or longer to save back the cost of an overdrive. Unless you drive an awful lot of miles.
I don't know why people resent paying for fuel so much. I don't like shelling out at the pump either. But you have to look at what you are getting for your money. Weight requires power in proportion to move it. When you look at the size of vehicle you are moving the fuel use becomes more reasonable.
The alternative is to travel in a VW diesel or possibly by train. If you want to enjoy a motorhome you have to face the fact of fuel use philosophically.
What is your MPG/Speed? Phil Gobie Tow Vehicles 34 10-16-2010 06:25 AM
Speed Traps Janet H On The Road... 48 12-12-2007 06:12 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
speed me up air66stream Forum Admin, News and Member Account Info 4 10-06-2007 10:58 PM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
