Old 03-15-2008, 03:40 PM   #1
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
2000 LY 350 XL speedo does not work help !!
All,
I picked up the beast today, had some work done on her nd now the speedometer does not work !!
This is a FORD frame
2000 LY 350 XL motor home
The other gages work, Odometer, tach, oil pressure etc..
Even the cruise control
just not the speedo
Any ideas ????
myfirstrv is offline   Reply With Quote
Old 03-15-2008, 07:55 PM   #2
myfirstrv's Avatar
Vermilion , Ohio
help "is there anybody out there ?"
Old 03-15-2008, 09:01 PM   #3
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi
If your cruise works then the cable from cruise control to speedo head is busted or ypu speedo is bad. Does your odometer work?Check that wich will tell you what is bad.
Regards from Russell In sunny and warm Tucson Az.
RUSSELL is offline   Reply With Quote
Old 03-15-2008, 09:39 PM   #4
myfirstrv's Avatar
Vermilion , Ohio
OK so the odometer works
I took the dash apart and I do not see a cable to the speedo
seems like its all electronic
so do I go to a dealer for the fix or a car parts store "Napa or auto zone?"
Regards
Rob
From Ohio -- Temp out side is 30 Degrees with the wind chill 27
degrees
Old 03-16-2008, 07:44 AM   #5
. , At Large
The speedometer is driven by electrical impulses from the speed sensor. If the odometer works, and the speedometer doesn't, it's probably in the cluster itself. Does your odometer use the LCD numers, or does it look like a regular odometer with the numbers that slowly turn as you drive?
Also, if it's not working, you can take the cluster to a speedometer shop, they will be able to fix it for you. If you take it to the dealer, all they will do is take it out, and take it to the speedometer shop.
Old 03-17-2008, 09:57 PM   #6
myfirstrv's Avatar
Vermilion , Ohio
All,
My Odometer is NOT digital ,NO LCD, looks like a regular odometer with the numbers that slowly turn as you drive.
Same is the speedometer,old type needle with the mph and kph
So take to a speedo shop? so what might this cost ??
I recently paid $7500.00 for a $3500.00 rear diff
so this question is a valid question and please let me know a range.
Also my trip is this Friday (family going to Wally world) so I'm going to use the GPS MPH, so anyone think that by not fixing this thing right away will cause MORE issues ?
Please all you gear heads (thats what they tell me you call yourselves) help an old guy out with this beast !!!!!
Old 03-17-2008, 10:02 PM   #7
myfirstrv's Avatar
Vermilion , Ohio
Terry,
Side bar,
Your dog looks like a relative of my hound , What is she / He ?
Old 03-18-2008, 05:45 AM   #8
. , At Large
Our dog was a peek-a-poo, w3eighed in at a hefty 8 pounds, though she thought she was bigger.
Your odometer is driven by a small electric motor with a worm gear on it, and the speedometer is also electrical.
It will probably run you $300 and up to get it fixed, and the shop may tell you to get a new cluster, and they will set your mileage.
Old 03-18-2008, 06:08 AM   #9
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Nationwide Speedometer and Instrument Cluster Repair
Judy At Home in Oklahoma
juel is offline   Reply With Quote
2000 ly 350 gas drive train myfirstrv Mechanics Corner - Engines, Transmission & More... 4 09-03-2007 07:18 PM
Speedo Woes - Parts Available? guy99 Airstream Motorhome Forums 6 10-27-2004 04:05 PM
speedo problems wb13798 Mechanics Corner - Engines, Transmission & More... 16 03-28-2003 03:07 PM
I'm looking for a 345 or 350? 4travel Airstream Motorhome Forums 2 01-14-2003 12:21 PM
