Old 07-21-2014, 02:41 PM   #1
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
1st electrical fire
Wifey here! Cruising down the road when I saw smoke coming from under the stove. Hubby used the extinguisher and clipped the wire. It was the ckt 4 Brown in the Univolt. We have a 87' 325 airstream. Pretty scary, but we are still motoring on. Nothing like a little adventure.
Thanks for any help.
gaiaenviro is offline   Reply With Quote
Old 07-21-2014, 02:46 PM   #2
gaiaenviro's Avatar
Forgot to ask the question! Does anyone know what this wire goes to?
Old 07-21-2014, 03:21 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I don't know the schematic for your motorhome, but you should check to make sure the fuse on that circuit is appropriately sized for the wire. In theory the fuse should blow before the wire catches fire, unless there was something readily flammable that lit from just a spark.
— David
Old 07-21-2014, 03:44 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
A loose connection can cause a fire without blowing fuse, arcing at the fuse caused a meltdown of the fuse holder to the a/c blower, with heat melted the fuse holder luckily it stopped working or fire would have been next.
Old 07-21-2014, 06:37 PM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Hope this 1st was also the last, no need to try for 2nd
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-21-2014, 07:48 PM   #6
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
A short....
Seriously, when you get where you're going for the night, try turning stuff on, and see what doesn't work. Then check the stuff on that circuit.
Old 07-21-2014, 08:19 PM   #7
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
If it is the original univolt, see if the light for AC power in the instrument panel is on when you are plugged in.
If I remember it correctly, the brown wire is low voltage AC current to power that light. Should all this hold true, you may want to consider replacing that old univolt asap with modern 55amp version, like an Intellicharger.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-21-2014, 09:03 PM   #8
gaiaenviro's Avatar
Hubby here, the brown wire is the one that fried/burned etc. I'll work I the change out next week....
Old 07-28-2014, 03:16 AM   #9
gaiaenviro's Avatar
Update:
Found the source of the short while looking for an unpleasant odor. Apparently a metal fitting had fallen off the heater under the bed in back and fallen onto the power wire which for whatever reason had lost its wire nut. This would explain the clicking on our last trip as we travelled down the road from the 12V system, I guess the screws loosened over time and the fitting fell slowly until the final screw came out and the fitting became the arc back to ground (furnace body). I plan to tear into it tuesday when I replace the wiring, univolt and fuse panel....
Old 07-28-2014, 06:03 AM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
While you're at it, don't forget to recharge the extinguisher you used! Never know when you might need it again; as the saying goes, "Better to have it and not need it…"
Cats and ultraleather Airstream upholstery don't mix!
FiRe, FiRe, FIRE, in the AiRsTrEaM!!!! TheBigRedTruck On The Road... 42 07-09-2019 06:32 PM
Electrical Fire after solar and inverter install jasperkins Electrical - Systems, Generators, Batteries & Solar 15 05-19-2014 03:55 PM
12 volt electrical fire wrochdvm Lights - Interior & Exterior 25 08-08-2012 06:17 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
FIRE! Electrical Short and Slide-Out Controller Fire rjd Electronics & Connectivity 10 07-24-2009 07:47 AM
