Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 01-04-2003, 01:38 PM   #1
Question 1988 classic 345 runs and stops
My 1988 345 has been parked for a couple years, I just started it runs great I get about a quarter mile and silence it stops, let it sit a few minutes, fires up goes again about a quarter mile and shuts down. I am confused could it be the fuel pump? the filter, the coil, I just don't know. Any help would be greatly appreciated
howardann is offline   Reply With Quote
Old 01-05-2003, 10:00 AM   #2
engine shutdown
Check to see if the exhaust system is stopped up, good luck!
benbailey is offline   Reply With Quote
Old 01-05-2003, 10:26 AM   #3
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
I would first replace all the fuel filters.
Some q-jets also have a small inline filter at the carburator inlet line.
Next I would replace the ignition module inside the distributor (you can always keep the old one as a spare if it turns out to be good)
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 01-05-2003, 03:51 PM   #4
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
My 1985 345 did the same thing and it took forever to figure it out. My problem was fuel flow. Airstream started adding supplemental electrical fuel pumps on the 1986 and later models. That's a long way from the tank to the engine! The electric fuel pump is near the fuel tank in the rear. I would check the pump wires. The local Truck and RV shop added the fuel pump for me and solved the problem.
Also, you probably have TWO fuel filters. One on the engine and another in-line filter near the door steps under the coach. I'd replace both just to be sure.
ViewRVs is offline   Reply With Quote
Old 01-05-2003, 04:06 PM   #5
LOST , Hawaii
And if you haven't already get rid of the old gas and get some fresh. Modern gas is only at it's best for 30 days.
John
74Argosy24MH is offline   Reply With Quote
