Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1964 Overlander
Old 08-21-2006, 03:19 PM   #71
GreatPumpkin's Avatar
Profile:  Currently Looking...
Colville , Washington
Images: 70
Sorry, I guess I should have read the question better
Definitely unscientific in my measurements (I used a bathroom scale), but the upright arms weigh about 15lbs each. It takes one bracket at the top and one bracket at the bottom of each upright/arm. The cross piece the arms attach to is almost 30lbs.
I'm sure there is some mathematical equation that says when the awning is extended that the weight each bracket supports changes, but I wouldn't even know where to begin on figuring that out
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 08-21-2006, 03:25 PM   #72
Images: 70
Picture to help explain?
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 08-21-2006, 03:41 PM   #73
NorCal Bambi's Avatar
Profile:  1963 16' Bambi
Yreka , California
Images: 21
Great Pumpkin, Sounds like Till has the resources and knowledge to remake the part you need. I have a suggestion after seeing where your parts broke. If the screws will still fit with the modification I'm making, They won't look too different. Just a thought.
Don
NorCal Bambi is offline   Reply With Quote
Old 08-21-2006, 05:14 PM   #74
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
Send a message via Yahoo to till
That is just what I need to know and see. Thanks!
Tedd Ill
AIR#3788
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 08-21-2006, 05:15 PM   #75
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
I have searched my garage, and don't have any extras of the parts you need. Hopefully Tedd's solution will work.
(No Longer at Inland RV)
Old 09-07-2006, 12:49 PM   #76
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
OK, sorry about the delay. I should have a PDF to post for approval this evening. Modeling shows a 12X safety factor with 100 lbs load.
Tedd Ill
AIR#3788
Old 09-07-2006, 01:11 PM   #77
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
submitted for your approval
OK so it didn't take as long as I thought...
Let me know what you think.
Tedd Ill
AIR#3788
Old 09-07-2006, 03:40 PM   #78
Images: 70
Thank you for your help
Almost - I guess I should have used a less ambiguous term than “shaft”. I was referring to a shaft in the male sense, as in a driveshaft, vs your rendering shows a shaft in the female sense, as in a mineshaft. The shaft slides into the upright arm of the awning at the top and bottom.
Looking at your rendering, and referring to the 4 drawings, I’ll call the top left #1, top right #2, bottom left #3, and bottom right #4.
Drawing #1
o The first hole from the left should be centered at .50 from the edge instead of .55 (the .875 between the holes is correct)
o The overall width is currently 1.125 instead of 1.5 (although wider width will work)
o If changing the overall width to 1.125, then the .75 measurement would be .5625 instead
Drawing #3
o The 2.5 measurement should be 2.75. The remainder of the overall length of 4.25 should be the male shaft. It is 1.5 in length, with a thickness of .781
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 09-07-2006, 09:23 PM   #79
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
To make, making the part easier, I am going to press a pin in the hole that you pointed out.
I tried (working with the pictures and engineer) to come up with a compromise that would work out best.
Drawing #1 I can move the holes down the .050 if you need.
Drawing #2 The length differeance is due to the angle. To make a angle that is easier to machine the length changed. The over all should still be the same. i.e. from the bottom mounting hole to the top where the pin will be inserted.
Also, the material will be 6061 aluminum with the machined surfaces left as machined. The pin I am not sure about just yet. I am thinking brass or maybe just some aluminum rod turned to the right diameter.
Does this help clear up your findings??
Tedd Ill
AIR#3788
Old 09-07-2006, 10:11 PM   #80
Images: 70
I think that clears it up, except the overall length? Currently the 4.25 length includes the shaft (or pin). If you machine it as pictured, then insert a pin that would increase the overall length by 1.5? Which would then require mounting the brackets further away on the airstream. That would put the top bracket further up the curve of the airstream body, changing the angle at which it sits. Or am I missing something?
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 09-08-2006, 07:04 AM   #81
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
I see the error now. My bad, I should have cross checked the picture to the print. I will get it revised drawing with the over all length (minus pin) set to 2.750 inches. Should be interesting to see what comes of this little mistake.
Tedd Ill
AIR#3788
Old 09-08-2006, 08:51 AM   #82
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
Take 2
OK lets try this again. The pin will be aluminum. Press fit then welded at the bottom (by where you will rivet it in place)
Tedd Ill
AIR#3788
Old 09-08-2006, 03:46 PM   #83
Images: 70
Till, that looks great.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 09-13-2006, 09:48 PM   #84
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
The drawing is in the shop and scheduled for a production run of four pieces. I will get a e.t.a. in a couple of days and then I'll PM you about the shipping side of things.
Night.....
Tedd Ill
AIR#3788
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 03:55 PM
Thinking of Buying '72 Overlander Joe C 1972 Overlander 16 07-20-2005 07:01 AM
receptacle replacement 1960 overlander rod Electrical - Systems, Generators, Batteries & Solar 3 10-31-2002 08:19 AM
tree on 69 Overlander pebblepoint General Repair Forum 2 09-10-2002 07:01 AM
2-door Overlander InsideOut 1958 - 1963 Overlander 0 08-30-2002 09:14 AM
