Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1964 Overlander
Old 05-11-2008, 11:04 PM   #1
Profile:  1964 26' Overlander
Reno , Nevada
Wink manual crank for electric tongue jack
Hello All. I have been busy restoring my 64' Overlander's exterior and found the tongue jack does not work. I opened the top and noticed there is a notch where possibly a manual crank can be attached to raise and lower the tongue. Is this true or do I have to get a battery to run the electronic jack? Any help is appreciated since next week I am driving to LA to hitch up to it. Thanks.
Croverlander is offline   Reply With Quote
Old 05-11-2008, 11:25 PM   #2
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Yes, that is a provision for a manual crank. You can make one out of some bar stock and a rollpin if you cant find the original.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-12-2008, 01:25 PM   #3
Profile:  2007 25' Safari FB SE
valencia , California
What he said and...
Before you use the electric jack again make sure to sync everything. So the leg and motor's switchs all agree on where the leg actually is.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 05-12-2008, 01:29 PM   #4
Marshall & Flordemayo
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
what they said and..........
once in a great while you see a used hand crank on ebay for a lot of bucks. If you make your own it would be pretty easy to make it so it fits in an electric drill.
I'm not sure if the battery needs to be in the coach but it is a 12 volt motor. so some how you need some juice. Check your fuses, jack switch, and that the wire to the jack is hot.
Unaware of Underwear
Old 05-12-2008, 01:46 PM   #5
Profile:  1971 23' Safari
Groveport , Ohio
Images: 18
Boy I would love to have a manual emergency crank but I dont know what Dia. of bar stock or roll pin to buy. Also how far from the end is the roll pin placed. Robert
bertro is online now   Reply With Quote
Old 05-12-2008, 03:42 PM   #6
Genoa , Nevada
Mine thinks it's at the stop place unless the battery is pretty well charged.
NevadaGeo is offline   Reply With Quote
Old 05-12-2008, 03:51 PM   #7
Excella CM's Avatar
Venice , California
If you make a crank, the rod diameter is what just fits inside the motor socket and the roll pin size and location are such that it will fit in the slots in said socket.
Old 05-12-2008, 04:31 PM   #8
Groveport , Ohio
Images: 18
Sorry I was being lazy and really didn't want to pull the head of the jack off. Any Dim. would be great. Robert
Old 05-12-2008, 05:58 PM   #9
Profile:
Hand Crank
Here is a photo of the emergency standby hand crank that came with my Airstream from the factory. I have had to use it on several occasions and it was effortless. As a matter of fact I am not sure why the motor sounds like it is laboring so hard when I use it.
This is a piece of 1/2" aluminum tubing with a 3/16" roll pin located 1/2" to center.
I have seen several people make a straight piece about 3" long and place in a cordless drill and not use the motor at all.
Best of Luck
flightlevel5 is offline   Reply With Quote
Old 05-19-2008, 08:47 PM   #10
Reno , Nevada
Thank you all. Luckily, when I arrived to pick it up, the crank was inside the cabin. Looks just like the one above. She has some bad wiring so I will have to investigate before the motor will be running.
Old 05-19-2008, 08:56 PM   #11
goransons's Avatar
Profile:  1969 25' Tradewind
Yakima , Washington
there is a crank for sale on ebay right now.
goransons is offline   Reply With Quote
Pingbacks are On
Can you get a manual crank head for a power jack? JimGolden Jacks, Stabilizers, Lifting and Leveling 2 08-05-2007 05:00 PM
Electric tongue jack help RVnDixie All Argosy Trailers 8 12-31-2006 08:54 PM
Manual Tongue Jack Failure Sugarfoot Jacks, Stabilizers, Lifting and Leveling 38 11-30-2006 07:09 AM
Electric Tongue Jack darryl97420 Towing, Tow Vehicles & Hitches 0 05-25-2006 08:57 PM
Tongue jack crank problems TDOW Jacks, Stabilizers, Lifting and Leveling 3 06-10-2005 06:21 AM
SEO by vBSEO 3.1.0
